Covalent bond of 2 or more atoms?
  • Context: High School
  • Thread starter Thread starter Goodver
    Atoms Bond
The discussion revolves around the nature of covalent bonds, specifically the possibility of sharing more than two electrons between atoms and the implications for molecular geometry. Participants explore theoretical frameworks, examples from chemistry, and the limitations of classical models in describing electron behavior.
  • One participant questions the standard model of covalent bonding, suggesting the possibility of sharing three or more electrons to form geometries like a tetrahedron.
  • Another participant argues that classical pictures of electrons are outdated and that quantum mechanics provides a better framework through atomic and molecular orbitals, which describe electron sharing in pairs.
  • This participant notes that while single and double bonds are common, they are not aware of stable molecules that share electrons among three atoms in the proposed configuration.
  • They mention cyclopropane as an example of a triangular arrangement of atoms, where bonding involves pair-wise sharing, and highlight the strain in such geometries due to orbital overlap.
  • A later reply introduces the concept of two-electron three-center bonds, citing boranes like B2H6 as examples where such bonding occurs.
Participants express differing views on the nature of covalent bonding and the feasibility of sharing more than two electrons. While some acknowledge the existence of multi-center bonds in specific compounds, there is no consensus on the general applicability of these concepts to all molecular structures.
The discussion highlights limitations in classical models of bonding and the complexities introduced by quantum mechanics. It also points out the challenges in visualizing electron sharing in multi-atom arrangements and the potential for higher energy configurations.
Goodver
I am not in Atomic physics,
Everywhere is the standard picture of a bond with 2 atoms sharing 2 electrons.
Why is it not possible to share 3 or more electrons that it would form something like a tetrahedron (see attachment)
Unfortunately, those types of pictures of electrons orbiting an atom are an old-fashioned and wrong picture of the electronic structure of an atom or molecule. With the development of quantum mechanics, we can attempt to visualize the electrons in an atom using atomic orbitals, which are a representation of the spatial density of the electron. As a quantum object, we can do experiments to measure the position of the electron at a specific time, but we cannot use a classical path to describe the behavior of the electron between measurements.
For molecules, we expect a similar description in terms of molecular orbitals. These can typically be approximated as combinations of atomic orbitals, which fits in very well with the interpretation that the atoms of a molecule "share" some of their electrons with one another. When a pair of electrons are shared between two atoms, we have a single covalent bond, when four electrons are shared a double bond, etc.
In considering the way atoms can be arranged to form a molecule, we have a competition between the relative attraction due to the formation of bonds and the relative repulsion due to electrostatic electron-electron and nucleus-nucleus repulsion. The more attractive the overall arrangment, the lower the potential energy and hence the more stable the resulting molecule will be. In theoretical chemistry, it is possible to compute molecular orbitals by adding up atomic orbitals and finding the particular sums that minimize the energy. This is a hard problem that almost always relies on numerical methods.
I'm not aware of any long-lived molecules that primarily share electrons between 3 atoms in an arrangement analogous to your picture. For example, cyclopropane is a triangular arrangement and there is a picture on that page showing the dominant orbital configuration, which involves pair-wise sharing. In terms of atomic orbitals there could be a small contribution where the electrons are shared by all 3 carbon atoms simulaneously, but it probably represents a higher energy configuration compared to the one pictured.
Actually, the cyclopropane geometry is already a bit strained, as you can also see on that diagram. The lobes of the atomic orbitals pictured there want to be straight. The bonding curves them around so that they can overlap, but this leads to a smaller binding energy than in ordinary, linear propane. The orbital that involves the 3-atom sharing is even more unnatural.
A case where it is easier to share electrons between more than 2 or 3 atoms is in aromatic compounds like benzene. There it is energetically favorable for the orbitals to "delocalize" as depicted in the 2nd figure in the Theory section on that page. This sort of delocalization that occurs most prominently in aromatic compounds is probably closest to the arrangement that you originally asked about.
fzero, thanks a lot, really helpful
Two-electron three-center bonds exist in boranes, for example. The most famous case is likely B2H6. http://arxiv.org/pdf/1306.6884 figure 6 contains some pictures of such bonds.
  • · Replies 34 ·
  • · Replies 23 ·
