Covariant derivative of coordinates
jfy4
Hi,
I am familiar with the covariant derivative of the tangent vector to a path, \nabla_{\alpha}u^{\beta} and some interesting ways to use it. I am wondering about
<br /> \nabla_{\alpha}x^{\beta}=\frac{\partial x^\beta}{\partial x^\alpha}+\Gamma^{\beta}_{\alpha\gamma}x^{\gamma}=\delta_{\alpha}^{\beta}+\Gamma^{\beta}_{\alpha \gamma}x^{\gamma}<br />
Then if we let this equal some arbitrary (1,1)-tensor we can manipulate to get
<br /> \frac{d\tau}{dx^{\alpha}}\frac{dx^{\beta}}{d\tau}+\Gamma^{\beta}_{\alpha\gamma}x^{\gamma}=\Omega^{ \beta}_{\alpha}<br />
which can be rewritten as
<br /> (\delta_{\alpha}^{\beta} +\Gamma^{\beta}_{\alpha\gamma}x^{\gamma}-\Omega_{ \alpha}^{\beta})u^{\alpha}=J_{ \alpha}^{\beta}u^{\alpha}=0<br />
which looks like a classic homogeneous linear algebra problem (that's the simplification I made in the last equality, just aesthetic). Does this equation have a good physical meaning, or is this just non-sense?
Thanks,
The covariant derivative applies to vector fields. As the coordinates do not form vector fields in a curved geometry, I don't believe taking their "covariant derivatives" will have any physical meaning. In the end, you don't have a (1,1) tensor since the x's are not vectors.
At the very best, I guess if you consider the coordinates to be functions (i.e. f(x)=x), then you have 4 separate one forms at the end, where the beta index merely labels which one form you have. In this case, the "contraction" with the Christoffel symbol is not kosher as the covariant derivative of a function is equal to the regular partial derivative.
okay, but I know one can take a parametrized covariant derivative, for quantities that evolve on a curve, x^{\alpha}(\tau), of the form
<br /> \frac{D}{D\tau}=\frac{d}{d\tau}+\Gamma^{\alpha}_{ \beta \gamma}u^{\gamma}<br />
like
<br /> \frac{DA^\alpha(\tau)}{D\tau}=\frac{dA^{\alpha}}{d\tau}+\Gamma^{\alpha}_{\beta\gamma}u^{\beta}A^{ \gamma}<br />
These quantities are not vector fields but are only defined on curves, like the spin of a particle. I'm also aware that x^{\alpha} does in general not transform covariantly, so I was worried about taking the derivative in the first place, which is why I asked the forum.
Thanks for your answer.
\frac{D}{D\tau}=\frac{d}{d\tau}+\Gamma^\alpha_{ \beta\gamma}u^\gamma only works if what that operator is acting on is a vector. If that operator is acting on a tensor, then the form of that operator will change. If that operator is acting on a function (e.g. f(x)=x), then the Christoffel symbol term is not there.
Essentially, \frac{D}{D\tau}=u^\gamma \nabla_\gamma. Remember that for a rank 2 tensor, the covariant derivative is \nabla_\gamma T^{\mu\nu}=\frac{d}{dx^\gamma}T^{\mu\nu}+\Gamma^ \mu_{\gamma\rho}T^{\rho\nu}+\Gamma^\nu_{\gamma\rho}T^{\mu\rho}, and this form changes depending on the rank of the tensor. Since your x is not a vector (but can only at best be thought of as a set of 4 functions...which aren't even scalars), I don't think your expression holds any physical meaning.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
