Create Math Graph using Matlab?
  • Context: MATLAB
  • Thread starter Thread starter basty
    Graph Matlab
6 replies · 2K views
basty
How do I create a graph of y = x^2 + x + 1 in Matlab?
Where I could create the above math graph in Matlab (please see below image)?
Type in command window the following:
Code:
x=[-5:0.2:5];
y=x.*x+2*x+1;
plot(x,y);
Code:
x=[-5:0.2:5];
y=x.*x+2*x+1;
plot(x,y);
What is the meaning of below code?
x=[-5:0.2:5];
Also, is y=x.*x+2*x+1; mean ##y = x^2 + 2x + 1##?
If so, then there is a mistake with the above code.
It should be ##y = x^2 + x + 1##.
What is the correct code of ##y = x^2 + x + 1## in Matlab?
You can remove the factor of 2, I put it by mistake.
Anyway, you would better start a free tour of Matlab documentation.
Thank you, but, the documentation doesn't help.
Can someone please tell me the order of creating math graph in Matlab with explanation?
I agree that taking the MATLAB tutorials would be helpful for you. These are basic syntax questions.
x=[-5:0.2:5];
This command tells MATLAB to create a vector called "x" with initial value -5 and final value 5 with intermediate values spaced .02 units apart.
You can adjust your initial and final values as well as your step size as you see fit.
y = x . ^2 + x + 1;
will create a vector called "y" which is the same size as x and for every value in x, it will compute x^2 + x +1. Notice the dot before the exponent: .^2 means to return the square of each element...as opposed to ^2 which tries to square the vector using matrix multiplication.
plot(x,y) is the simplest graphing option and requires that the two vectors be the same length.
