Creating a system of equations consisting only of integers?
friedrice821
I'm looking for an algorithm to create a very simple (2 equations, 2 unknowns) linear system of equations that consists purely of integers. Specifically, a way to create a system of equations of integers and knowing that it can only be solved by integer answers, without actually solving it.
a11x1+a12x2=b1
a21x1+a22x2=b2
where a11, a12, a21, a22, x1, x2, b1, b2 are all integers.
The only thing I can think of is using a determinant which gives
x1 = (a22b1-a12b2) / (a11a22-a12a21)
x2 = (a11b2-a21b1) / (a11a22-a12a21)
and that the numerator must be a multiple of the denominator.
What do I do now? Am I even on the right path?
Mathematics news on Phys.org
You don't say why you want to do this, but if you want to geerate "random" questions for an online test or something similiar, the easy way is to just pick a, b, c, d, x1 and x2, and then work out y1 and y2.
If this is a more general question, look up "euclid's lemma" and linear Diophantine equations, e.g. http://en.wikipedia.org/wiki/Euclidean_algorithm
Thanks! the Diophantine equations really helped.
By the way, I wish you hadn't used y1 and y2...it just throws a curve ball as to they are supposed to be known constants or unknowns...maybe you should simply use a couple of more letters?
...just being picky.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
I'm interested to know whether the equation $$1 = 2 - \frac{1}{2 - \frac{1}{2 - \cdots}}$$ is true or not. It can be shown easily that if the continued fraction converges, it cannot converge to anything else than 1. It seems that if the continued fraction converges, the convergence is very slow. The apparent slowness of the convergence makes it difficult to estimate the presence of true convergence numerically. At the moment I don't know whether this converges or not.
