Creating an Efficient Atmospheric Powerplant with Hot Air Balloon Principles
In summary, the main idea of global warming is that greenhouse gases trap heat on the surface of the planet. To combat this, an atmospheric powerplant is proposed, which would move heat from the lower layers of the atmosphere to the upper layers. This would be achieved through a construction that circulates moist air between the layers, similar to a tropical cyclone. In order to make this construction cost-effective, it is suggested to use principles from hot air balloons. The powerplant would also have the ability to convert mechanical work into electricity and use a hydrogen reserve for fuel. The energy produced would be transferred to the ground through an electrical network and floating platforms in the seas and oceans. However, some argue that adding a vertical turbine to the power
global_frozin
Please, write what is wrong with this reasoning:
ATMOSPHERIC POWERPLANT
The main idea of global warming is that greenhouse gases prevent the energy from leaving the surface of planet. In the same time the upper layers of the troposphere are much colder and successfully emit the infrared radiation to the outer space. So to stop the global warming it is necessary to organize the moving of the heat from the lower layers of the atmosphere to the upper layers.
Also we know that the heat engine performs the conversion of heat energy to mechanical work by exploiting the temperature gradient between a hot "source" and a cold "sink". So the moving of the heat from the lower layers of the atmosphere to the upper layers can be done with some output of the mechanical work. The amounts of this mechanical work can be huge as we know on example of a tropical cyclone. The working body of the cyclone is simply the moist air, which releases the heat by water vapour condensation when rises. So to make the atmospheric heat engine it is necessary to make the construction in which the moist air is circulating in organized manner between the lower and upper layers of the troposphere. Therefore the height of this construction has to be about the height of the troposphere. Also this construction has to be able to withstand the strength of the winds. These requirements can make the creation of such constructions too expensive and non profitable.
To solve the construction problems of the atmospheric heat engine the present synopsis suggest to use the principles of the hot air balloon. If the moist air, which is the working body, will have the average temperature, which is higher then the average surround air temperature, then the atmospheric heat engine will be buoyant. In this case the powerplant will travel with air and it will not be necessary to withstand the winds. Also in this case the construction will be as light and cheap as possible for such a device.
To get the additional energy to keep the average temperature difference the atmospheric powerplant can convert some part of produced mechanical work back into the heat energy. Also to minimize the necessary temperature difference the device can be constructed as Rozière balloon which has separate chambers for a non-heated lifting gas (such as hydrogen or helium). While traveling over the water surface the atmospheric powerplant can replenish its hydrogen reserve by converting the water into the hydrogen and the oxygen. In this case some part of hydrogen can later be used as fuel to increase the temperature of the working body.
The possible structure of the atmospheric powerplant is depicted as dissection on the picture:
1 - chambers for a non-heated lifting gas
2 - top part of the balloon, which dispose the heat to the top layers of troposphere
3 - the lower part of the balloon, which absorb the heat from the lower layers of troposphere
4 - turbine, which convert part of mechanical work into electricity
5 - heating device, which works using electricity or hydrogen combustion
6 - utility unit which works as ballast and can contain electrical accumulators, control system, pilot cabin, wires and pipes to connect with the ground, connection sockets, etc.
To transfer the produced energy to the ground the atmospheric powerplant can convert mechanical work to the electricity and then use the cellular network of sockets. The connection and disconnection has to be made on the fly without stopping the powerplant using some device like helicopter. In the seas and oceans such sockets can be placed on special floating platforms with electrical accumulators or devices, which convert the water into the hydrogen and the oxygen.
The illustrated synopsis:
http://docs.google.com/Doc?id=dcvrsh6t_17c859bsfm
Adding a vertical turbine won't create flow, it will restrict flow, harnessing energy that is already there. In this case, it would just be harnessing thermals. But no need: As your diagram correctly indicates, the flow is circular, so you can harness it at any point in the cycle, such as horizontally on the ground. Ie, with wind turbines.
Water vapor is the #1 cause of greenhouse effect. Carbon dioxide is next, and although human activity contributes about 5% of the total production of carbon dioxide on the earth, most of the 95% of the carbon dioxide produced by nature, is also absorbed by nature absortion, and so the current average is about 30% higher than the long term average before 1750 (although there is evidence of high levels of CO2 from 7,000 to 10,000 years ago).
http://en.wikipedia.org/wiki/Greenhouse_gas
Wind turbines depend on weather, sometimes calm, sometimes cyclone. Atmospheric powerplant will try to permanently maintain the cyclone inside .
So it will try to make the windy weather all the time. :-)
The wind turbines do not solve the global warming problem, because they do not change the current atmospheric activity, which is not high enough now to carry the surplus heat outwards the atmosphere.
One of the byproducts of the atmospheric powerplant will be the precipitations,
because the work of such a device will produce the mixing of the layers with different temperatures.
The precipitations will increase the amount of water kept on the eath surface and decrease the amount of water kept in the atmosphere.
In order to make wind, you need a fan. So this device will not generate energy, it will consume it.
Also, you misunderstand the issue of the thermal gradient. Thermals start as a bubble of warm air near the ground that rises because it is less dense than the cooler air just above it. But as the air rises, it expands and when a volume of gas expands without a change in energy, it cools. So there is a limit to the height that this air can rise due to the amount of energy in it.
Remember: it is density differences, not temperature differences that create thermals. As I said above, thermals and wind are two parts of the same cycle and this cycle is powered by heat from the sun. It doesn't work at night or when it is cloudy because there is less/no solar heating.
You describe the conditions for thermals. What about conditions for cyclones?
Wind is wind. They all work basically the same way. Cyclones just get their energy from warm water instead of ground warmed by the sun.
Only scanned the thread.. Tests with tall hollow cyclenders are taking place in such as Isreal.
Yes, those devices harness pre-existing thermals, though they trap air under huge tent-like structures to maximize energy capture. An intriguing idea worthy of some study, but I have my doubts about the viability of the concept due to the physical size requirement of these structures.
According to model calculations, a simple updraft power plant with an output of 200 MW would need a collector 7 kilometres in diameter (total area of about 38 km²) and a 1000-metre-high chimney.
http://en.wikipedia.org/wiki/Solar_updraft_tower
Hey Russ remember this one:
http://www.enviromission.com.au/project/project.htm
Unfortunately, I'll bet somebody is going to throw in the http://en.wikipedia.org/wiki/Energy_tower_(downdraft)" one soon! Oh wait, I just did...Opps!
CS
It is not the same way, because the ciclones use the moist air as the working body.
Let's describe Carnot cycle of cyclone.
Suppose we have only the dry air. When going up the temperature decreases, but the pressure outside also decreases, so our piston will not move.
Then consider some greenhouse gas in the air. The decrease of pressure will not exactly correspond to the decrease of temperature, so our piston will move a little,
producing the work, which correspond to the temperatures difference created by greenhouse gases.
Then consider some water in our cylinder. At lower point it is the gas inside the air. 100% humidity inside. At upper point it will be drops of water. The piston will make a big move, will not it?
The atmospheric powerplant will keep the circled pipe with the moist air in which the flow will go organized, in one direction.
This circle will connect the cold and warm layers of troposphere.
Yep, that's the one. We've discussed it before. I was trying to be deferential regarding the concept (scientifically, there is nothing at all wrong with it). I was pretty explicit about what I really think about that particular corporation, though, in other threads about it.
Your description is ok, but it doesn't address the claim you made initially: you claimed that your device would increse circulation while generating power. Ie:
That's all true too, but it does not imply that it will increase the circulation, only that it will harness already existing circulation.
The first law of thermodynamics applies: you cannot increase energy transfer while simultaneously removing eneryg from the system via an interruption of that energy transfer.
russ_watters said:
Your description is ok, but it doesn't address the claim you made initially: you claimed that your device would increse circulation while generating power. Ie: That's all true too, but it does not imply that it will increase the circulation, only that it will harness already existing circulation.
That is strange, but how do you think the geothermal power stations work? :-)
It is possible to increase the circulation and take only part of its power.
The atmospheric powerplant will increase the circulation by placing more effective working
body between the layers with different temperatures. You will have the tropical cyclone in Sahara, I promise. :-)
For example, we have a circled pipe with moist air ( 10 diameter of circle, 1 km diameter of pipe ).
Suppose the relative humidity around it is less then 100% and always 100% inside.
A the top and bottom points we have the temperature and pressure equal to what we have around.
At top point our moisture will be in form of droplets. If the humidity around it is less then 100% then at top point the air inside the pipe will have the density higher then around. So this will provide us with the force, which will pull our flow down.
At low point our moisture will be in form of gas. If the humidity around it is less then 100% then at low point the air inside the pipe will have the density smaller then around ( H2O gas is less dense then air ). This will provide us with the force, which will pull our flow up.
This is the Carnot cycle of cyclone from my point of view. We need to start the engine by moving the flow it one direction ( clockwise or counter-clockwise ).
As a result the speed of wind inside the pipe will grow until at the top and bottom points we will not have enough time to equal the temperature and pressure.
The device as a whole will work until it will have the 100% humidity around or all the layers of air mixed and having the same temperature ( stable column of air :-)
Also I hope that Coriolis forces will spin it so it will organize the cyclone-like structure of winds around. As a result it will have the inflow of warm air at the bottom,
the flow-out of warm air at the top and the state of stable column of air will never be achieved.
No, you won't. You are wrong on both counts.
1. Your device won't increase circulation.
2. You can't increase circulation while generating power.
You didn't say how you think this is similar to geothermal power, but in any case, it isn't.
None of that has any meaning that I can discern. It is jut word salad. Gibberish.
You didn't say how you think this is similar to geothermal power, but in any case, it isn't. None of that has any meaning that I can discern. It is jut word salad. Gibberish.
You are fixed on isolated systems. In isolated system it is impossible to generate power by increasing the circulation. The geothermal power is not isolated system. The heat goes one way. Atmospheric powerplant is the same. The heat goes up and then leaves the planet by infrared.
In isolated system if you generate the power you decrease the circulation because the both things are energy which cannot be changed in isolated system.
You consider the atmosphere as isolated system and the wind power as a way to produce electricity by decreasing the circulation. Really, the wind turbines, which are using the trifling amount of atmosphere circulation will slightly intensify the global warming by decreasing the circulation and so decreasing the loss of heat by infrared.
But the atmosphere circulation itself is not isolated system. Every storm or cyclone moves the heat up and so it gets over the greenhouse gases and then leaves the planet by infrared. This is the process which we need to intensify to fight the global warming.
Anyway thank you for criticism, it was somehow informative for me. :-)
Related to Creating an Efficient Atmospheric Powerplant with Hot Air Balloon Principles
What is an atmospheric powerplant?
An atmospheric powerplant is a type of power station that harnesses the energy of the atmosphere to generate electricity. It uses the principles of hot air balloons, such as the difference in air density, to produce a continuous supply of energy.
How does a hot air balloon principle work in an atmospheric powerplant?
In a hot air balloon, the air inside the balloon is heated, causing it to become less dense and rise. This principle is applied in an atmospheric powerplant by using a heating element to warm up the air, causing it to rise and turn a turbine, which then generates electricity.
What are the advantages of using hot air balloon principles in an atmospheric powerplant?
One of the main advantages is that it is a renewable source of energy, as the sun's heat is used to warm up the air. It also has a low impact on the environment, as it does not produce any emissions or pollutants. Additionally, it is a cost-effective method of generating electricity.
Are there any limitations to using hot air balloon principles in an atmospheric powerplant?
One limitation is that it is highly dependent on weather conditions, as the air temperature and wind patterns can affect the efficiency of the powerplant. It also requires a large open space to operate, which may not be feasible in urban areas.
Can an atmospheric powerplant be used as the sole source of electricity for a community?
It is possible for an atmospheric powerplant to provide a significant amount of electricity for a community, but it may not be able to meet all of its energy needs. It can be used as a supplement to other sources of energy, such as solar or wind power, to create a more efficient and sustainable energy system.
  • Astronomy and Astrophysics
