Crosswind problem (pgs. 34-35, Thinking Physics, 3rd edition)
327 replies · 16K views
The orientation of the sail is not correct at #149.
The sail has no orientation in that diagram. Its orientation relative to the cart is characterized by the parameter ##\beta## which I hope to first optimize as a function of ##v_x##. I.e the expectation is that there is a little man on the boat that is turning the sail to maximize the component of the applied force ##F## in the direction of motion over the entire duration of the analysis.
The optimal sail would be bisecting between apparent wind direction and boat direction, the force on the sail is perpendicular to the sail plane. That mean the optimal force direction is known for every boat speed.
If the sail were fixed at the angle ##\beta##(making it a constant), that you say it is ( whatever it is), with the force ##F## perpendicular to the sail that implies that ## \frac{F_y}{F_x} ## or ## \frac{F_x}{F_y} ## is a constant w.r.t. to velocity.
The problem with that is:
$$ F_x = \dot m \left( w \sin ( \beta + \theta ) + v_x - w \right) $$
$$F_y = \dot m \left( v_y - w \cos ( \beta + \theta ) \right) $$
If you sub ##v_y = v_x \tan \theta## it should be apparent by inspection that isn't the case as:
$$ \frac{F_x}{F_y} = \frac{w \sin ( \beta + \theta ) + v_x - w}{ v_x \tan \theta - w \cos ( \beta + \theta ) } = f(v_x)$$
There is no one that wants it to be a constant more than I do right now, as the solution to that problem is straight forward...but its not. @A.T. already made a point of this in an earlier post.
Here is illustration of sail boat diagram.
The boat is descending downwind faster than wind, but you can see, that the sail line is moving slower than wind. That makes possible for wind to make a force on the sail, which has a component (not illustrated) keeping or accelerating the boat speed.
Do you have questions to this diagram?
Its not analysis. Quit patronizing me with "vectors" that supposedly reduce everything I just went over to nothing. I am applying Newtons Laws of motion, as instructed to do so by the Fluid Mechanics textbook sitting in front me. I don't accept..."but look at randomly drawn vectors", so stop wasting your time. If you are a physicist, you should be much more inclined to hear what Newton has to say about, or figure out how what I'm saying is incorrect in an agreed upon framework of Classical Physics i.e. Newtonian Mechanics and tell me about it.
Your flow analysis suppose to come to the same. What way do you defining the outgoing flow?
Look at the diagram. It shows everything I have planned.
This equation represents Newtons Second in Fluid Mechanics under the assumption of constant cross-sectional properties:
$$ \sum F = \frac{d}{dt} \int_{cv} \rho v ~d V\llap{-} + \sum_{cs} \dot m_o v_o - \sum_{cs} \dot m_i v_i $$
Vectors indeed simplify the analysis substantially.
Just because you have a hammer, doesn't mean every problem is a nail. We don't have to go into the complex details of fluid dynamics, because we have empirical data on achievable lift/drag ratios, which leads to the much simpler vector analysis.
What have vectors done to you, that you hate them so much?
Here is a paper by a physics professor in a physics journal, analyzing the same thing and using vectors of course:
High-speed sailing, Wolfgang Püschl 2018 Eur. J. Phys. 39 044002
https://iopscience.iop.org/article/10.1088/1361-6404/aab982
Reply
OK, but note that:
- the example ##\beta## you have drawn is wrong for maximizing ##v##. See post #142.
- you have drawn the relative outgoing flow again, because it is parallel to the sail. This is not how the outgoing flow looks like in the ground frame where the sail is moving.
But your diagram doesn't have ##\dot m_o v_o## in it. The outgoing flow is labeled ##\dot m w##, which is of course wrong, because the flowspeed ##w## (in the ground frame) will change after the interaction with the sail.
So how do you plan to determine that ##v_o## for all possible speeds of the boat?
The problem is that you don't understand that I'm adding vectors ( well, technically scalars that are associated with the component vectors)! I wrote out the forces acting on the sail in post #154. For example: The momentum of the incoming flow for ##F_x## has three terms; the first two combined describe the momentum of the outflow (notice the dependency of the outflow momentum on component of cart velocity w.r.t the ground frame). The last term describes the momentum inflow relative to inertial frame.
The subscripts ##i,o## refer to inflow, outflow respectively. The problem here, given this statement and the fact that I have done this analysis 5 times over with this notation in this thread means that you haven't actually tried to digest any of it until just now.
A.T. said:
Vectors indeed simplify the analysis substantially.Just because you have a hammer, doesn't mean every problem is a nail. We don't have to go into the complex details of fluid dynamics, because we have empirical data on achievable lift/drag ratios, which leads to the much simpler vector analysis.What have vectors done to you, that you hate them so much?Here is a paper by a physics professor in a physics journal, analyzing the same thing and using vectors of course:
Vectors are not physics! They are a small part of the process. They do not in and of themselves encapsulate it, and or complete an analysis.
If we are talking fluid mechanics, we are talking Newtons Second, whether it be through the simplified model im proposing, or the more detailed Navier-Stokes Equations.
Reply
  • Skeptical
A.T. said:
OK, but note that:
I said ##\beta## is a parameter I was proposing to optimize as a function of ##v_x##, to maximize ##F \cos \gamma##.
This is not a diagram of the flow throughout all time and space. It is a snapshot capturing the momentum change of the impinging jet immediately before and after impacting the sail at some specific time, location on the infinite planar sail.
erobz said:
If we are talking fluid mechanics, we are talking Newtons Second,...
Sure, but you don't have to go back to Newton's Laws for every fluid mechanics problem. In particular for the aerodynamic forces on airfoils we have tons of experimental data, which is more reliable, than what you get by simplifying the situation, in order to solve it analytically.
Reply
I can tell you right now I don't have a prayer of solving it analytically. Numerically...maybe. But that has been my whole point. We have this analysis (which is not the analysis of an airfoil, but is a step in that direction) which appears to be virtually humanly unsolvable in general, and you were telling me to just look at some randomly drawn vectors and animations, while critizing my "vectors" that are used as part of an analysis in a traditional way.
If you are able to site a CFD analysis that specifically proves downwind travel faster than the wind in the idealized case presented here, post it. I mean, if this is such a hot button issue I'm finding it hard to believe there aren't any experts that have created the rather theoretically simple CFD model to demonstrate it.
Reply
  • Skeptical
erobz said:
...you were telling me to just look at some randomly drawn vectors...
No, I'm telling you to look at vectors, which are consistent with real world lift/drag-data for airfoils. This removes the whole messy fluid dynamics from the problem. Even for a numerical approach you can use empirical lift/drag-data, instead of CFD.
"Sure, it works in reality, but can you show it in CFD?"
"Reality" is messy and an uncontrolled environment. Show it in the laboratory, or simulation where experimental parameters are mostly controlled\fully controlled.
Reply
  • Sad
Ice boats can do 4 x windspeed in the downwind direction. This is way more than the variability of the wind.
The experimental lift/drag-data for airfoils comes from the lab (wind-tunnel). And and it implies that downwind faster than the wind is possible. Which is consistent with outdoor experimental data.
A.T. said:
Ice boats can do 4 x windspeed in the downwind direction. This is way more than the variability of the wind.The experimental lift/drag-data for airfoils comes from the lab (wind-tunnel). And and it implies that downwind faster than the wind is possible. Which is consistent with outdoor experimental data.
Color me skeptical, and prove it with CFD.
Reply
  • Sad
erobz said:
prove it with CFD.
That is not how physics works. It's an empirical science based on experiments. We know lift/drag-data for airfoils from experiments, so we don't need CFD to "prove" that it is possible.
This wasn't about a wing, this is about a vane. There is a difference. You are telling me that the solution for a simple vane should be faster than the wind in the direction of the wind...given the complexity of the equations I will derive I say, prove that with CFD. A thin straight (or curved) sheet of canvas, does not an airfoil make.
It doesn't mater how you call it. All that matters is that you have something that can create much more lift than drag. The rest is trigonometry and vector math.
Reply
I just showed you that is substantially more complicated than that! You are ignoring it and defaulting to your "just add the vectors" non-analysis "analysis".
Reply
  • Skeptical
No. You just showed that one can make it more complicated than it needs to be.
There is no need to go back to Newton's Laws or use CFD here, because the question is not how lift is generated on the fundamental level. The question is how fast the boat can go downwind, given the empirically known performance of airfoils.
Why have you goaded me back into this conversation? I walked away 50 posts ago, last month to allow you your delusions of simplicity. You called me back for a fight when you thought you had reinforcements.
I'm walking away again. I won't coming back to this, so feel free to trash what I've done all you want.
Take Care.
Reply
  • Sad
erobz said:
... your delusions of simplicity....
I'm proposing to keep the fluid dynamics details of lift generation out, because I know it's not simple. But we also know empirically that it works, so it can be taken as given.
I was keeping fluid mechanics of lift generation out of it. There is no lift generated on the vane. It is not an airfoil.
Lift is the force component perpendicular to the relative flow. Your vane will certainly produce some lift, at most angles of attack (all except +/- 90°). Even a brick can produce some lift. But key to performance is the ratio of lift to drag, which determines the angle between relative flow and aerodynamic force. The rest follows from those angles.
There is no flow over the vane. There is a force from the impulse of the jet changing it’s momentum. Is that what you are calling lift, because that’s not what I would call it. My analysis is happening in a vacuum. There is no lift, there is no drag….
