Why Isn't My Raltron Crystal Oscillator Causing the Diode to Blink?
  • Thread starter Thread starter David lopez
    Crystal Oscillator
The discussion centers on troubleshooting a Raltron crystal oscillator that fails to blink a diode. Key points include the necessity of using an oscilloscope for effective troubleshooting and the recommendation to start with lower frequency oscillators, such as 1 MHz, to simplify circuit construction. High-frequency circuits, like those operating at 100 MHz, require specialized techniques to manage parasitics and avoid issues with solderless breadboards. Proper circuit layout, short interconnections, and shielding are critical for high-frequency applications. The conversation concludes with a warning against using high-frequency components without appropriate testing equipment, such as a frequency counter.
David lopez
I bought a raltron crystal oscillator.
I connected it to a programmable frequency divider. It is supposed to cause a diode to blink on and off. The crystal oscillator has a rated frequency of 100 megahertz. The programmable frequency divider can divide a frequency by up to 2,147,483,648. Diode won't blink. How do I troubleshoot the crystal oscillator?
Without an oscilloscope, you won't.
Likes davenn and berkeman
Can you post your schematic and a picture of how you hooked it up?
Also, it's probably best to start with an oscillator around 1MHz (or even 32.768kHz), to make the circuit easier to deal with. Circuit construction around 100MHz takes specialized techniques that you can learn later.
David lopez said:
Diode won't blink.
if the oscillator frequency is more than around 50Hz, then you won't see it blink
It will be too fast for your eye to see
What are these specialized techniques?
VHF (very high frequencies) and up require careful circuit layout and construction
so that they work correctly ... for example
1) .. they cannot be built on those solderless breadboards ( like you have been using)
2) .. interconnecting wiring between components must be kept as short as possible
because if they are too long they can become significant inductance or become antennas
3) .. shielding between stages/sections
4) the use of feedthrough capacitors and ferrite beads to stop RF getting back out onto
power supply lines
the list goes on ...
Now that is just some of the construction issues
Testing is another whole ball game. Suitable test gear for the frequencies being experimented with
are essential ( now that goes for all circuits but becomes more critical as the frequencies increase)
As the frequencies increase, the cost of good/reliable test gear also increases.
I have many $1000's of test gear here that I use on VHF, UHF and into the microwave bands
up to 24 GHz
Spectrum analyser to make sure a signal is clean -- no harmonics present or at least very reduced
RF power meters to know how much power is being produced
Frequency counter(s), I have 3 for different uses, to make sure you are producing a signal
on the correct frequency
Decent quality, high impedance, multimeter
Decent oscilloscope for looking as waveforms etc of various signals
again, the list goes on as you get more into it...
Likes berkeman
So I should avoid using a solderless board?
At 100MHz? Yes, please avoid that. :smile:
Likes davenn
Why can't they be built on solderless
Boards?
Boards?
Basically, you need to control parasitics (capacitance, inductance, coupling) very carefully in high-frequency circuits. A wire is not just a wire, it's an inductor and an antenna. A capacitor is not a capacitor anymore, the parasity inductance associated with it makes it a tuned circuit. An inductor is no longer an inductor, its parasitic capacitance shorts out much of the inductance...
:smile:
Likes davenn
Here is a good book that describes the digital side of high-speed design. It was written by a very bright guy who used to work at the company that I still work for. Our CEO bought copies for every hardware engineer in the company when Howie first published it... :smile: See if your local technical library has a copy that you can look through...
245481
I am planning to buy a microchip that
Contains a voltage controlled oscillator
Rated at 2.4 gigahertz that will work on a breadboard?
what do you think in the light of what you have been told in the above posts ?
ohhh ... and do you have a frequency counter that goes to at least 2.5 GHz
so you know the exact frequency you are radiating RF energy on ?
If not, don't get the oscillator module till you have spent good money on a frequency counter first
How do prototype circuits that contain this chip?
a PCB .. Printed Circuit Board
Is that the only way?
The original question has been answered.
Thread closed.
  • · Replies 27 ·
10K
  • · Replies 18 ·
