Curious about an idea of a modified polariser to send signals with QE
  • Context: Undergrad
  • Thread starter Thread starter tade
    Curious Idea Signals
The discussion revolves around the concept of using a specially modified polariser to send signals through quantum entanglement, exploring its theoretical possibilities and implications in the context of Bell tests and measurement outcomes.
  • One participant proposes the idea of a modified polariser that could shift measurement results from a 50/50 probability to a 52/48 probability, suggesting it could allow for signalling between entangled particles.
  • Another participant argues that Bob only sees random outcomes regardless of Alice's actions, stating that correlations can only be observed when comparing results from both Alice and Bob, which requires standard signalling.
  • There is a suggestion that Bob might observe changes at his end due to Alice swapping polarisers, but this is challenged by others who assert that Bob's results remain random and unaffected by Alice's choices.
  • A participant questions why swapping the polarisers does not lead to a change in outcomes, to which others respond that random outcomes cannot be controlled.
  • One participant introduces the idea of entangling Bob's photon with Alice's actions, prompting a request for a detailed scenario to analyze this possibility.
  • There is a reiteration of the original scenario, with some participants expressing frustration over the repetitive nature of the discussion without new insights being added.
Participants generally disagree on the feasibility of using a modified polariser for signalling through quantum entanglement. While some explore the theoretical implications, others maintain that the outcomes remain random and independent of Alice's actions.
The discussion highlights limitations in understanding the relationship between polariser settings and measurement outcomes, as well as the need for clarity in defining the proposed scenarios involving entanglement.
  • #91
vanhees71 said:
But within relativistic microcausal QFT by construction there are no spooky actions at a distance, only long-ranged correlations between parts of an entangled quantum system.
though i think there's the question of how they get correlated at a long-range within a very short duration, for example the lower bound of the "entanglement speed" being 10,000c
  • #92
They get correlated through the preparation procedure. E.g., to have two photons in an entangled state you can use parametric downconversion and select only entangled pairs, i.e., these two photons moving in different directions are all the time entangled until they are detected, and the detection events can be as far as you like. As long there's no interaction of the photons on their way to the detector you'll just measure the strong correlations (of their polarization) which are there all the time since the photons have been created.
  • #93
hmm that does sound like spooky action at a distance lol
  • #94
Why should this be spooky action at a distance? The photons have been created by a local action, e.g., when using parametric down-conversion the interaction of a laser beam with a BBO.
  • #95
as in, hmm, maybe you can elaborate on the part about the photons being all the time entangled
  • #96
You create two photons in an entangled state, like
$$|\Psi \rangle=\frac{1}{\sqrt{2}} [\hat{a}^{\dagger}(\vec{p}_1,h=1) \hat{a}^{\dagger}(\vec{p}_2,h=-1) -\hat{a}^{\dagger}(\vec{p}_1,h=-1) \hat{a}^{\dagger}(\vec{p}_2,h=1)]|\Omega \rangle.$$
If neither of the photons interact with anything, they stay in this state forever.
  • #97
oh i see, and i was thinking that if both are measured in quick succession, as both are entangled, there could be the spooky action at a distance
  • #98
This phrase is meaningless unless you define what, in the actual math, it corresponds to. So far we have had two possible definitions: violation of the Bell inequalities, and entanglement of the two photons. Neither of these seems to be what you mean, but you seem unable to give any other definition. If that is the case, there is probably no point in continuing this thread, since the actual physics has already been discussed in some detail.
  • #99
maybe another notion would be one photon sending info to the other photon instantaneously across a great distance
and i would also like to ask about taking a look at any literature on the the maths and mechanics of the situation at the moment when the wave encounters the molecules of the polariser, the interaction of the target particle with the polariser molecules, like the photon-polariser interactions at the quantum-molecular level, or also the maths of the transition when and as the wavefunction is collapsing as it encounters and interacts with the molecules of the polariser
though yeah i think some of the parts might not have existent literature as of yet
  • #100
I said something in the actual math. I did not say whatever your imagination can dream up.
This is well beyond the scope of a single PF thread. Basically you are asking for a complete course in quantum measurement techniques and solid state physics.
The thread topic has been sufficiently discussed and personal speculation is off limits here at PF. Thread closed.
  • · Replies 61 ·
  • · Replies 80 ·
9K
  • · Replies 41 ·
  • · Replies 16 ·
  • · Replies 56 ·
  • · Replies 35 ·
  • · Replies 37 ·
