Curious Question about Velocity
  • Context: Undergrad
  • Thread starter Thread starter Only_Curious
    Curious Velocity
The discussion centers around the scenario of firing a bullet from a gun on a moving train, specifically examining the resulting velocities of the bullet relative to the train and an observer on the ground. Participants explore the implications of classical mechanics and relativistic effects, considering both everyday speeds and the limits of high-speed scenarios.
  • Some participants suggest that the bullet will travel at approximately 2X when fired in the same direction as the train, while others note that relativistic effects must be considered at high speeds.
  • One participant emphasizes that the bullet's speed relative to the ground will be less than expected due to relativistic effects, particularly when the speeds approach that of light.
  • Another viewpoint states that if the bullet is fired in the opposite direction, its speed will effectively cancel out with the train's speed, leading to a scenario where it appears to be stationary to an observer on the ground.
  • Some participants argue that a bullet fired backwards from a train moving at the same speed will fall straight down relative to the ground, while others challenge this by stating that the bullet will still have a horizontal component of motion.
  • There is a discussion about the perceived motion of the bullet, with some participants claiming it would appear to hang in the air, while others clarify that it would fall to the ground as if dropped from rest.
Participants express multiple competing views regarding the bullet's motion and speed relative to different frames of reference. The discussion remains unresolved, with no consensus on the implications of firing the bullet in different directions or the effects of relativistic speeds.
Participants highlight the importance of considering relativistic effects at high speeds, as well as the assumptions about the bullet's speed relative to the train and ground. The discussion also touches on the complexities of motion in different frames of reference.
Only_Curious
Can someone explain to me what will happen in this scenario?
Imagine you are in a train which is traveling at velocity X. In it, you fired a gun which points towards the direction of the moving train launching the bullet out at the same velocity. Will this cause the bullet to travel at 2X? What if it was fired in the opposite direction?
The important thing is not to stop questioning.
Albert Einstein
You can already answer this yourself. Our Earth is moving at a velocity X with respect to some other planet. And yes, we have fired MANY guns in many different directions already.
So now ask yourself, how fast is the bullet moving with respect to you, on the earth, and with respect to another person on that other planet.
Zz.
I suppose that you mean that the velocity of the bullet determined with respect to the train, while the velocities X and 2X are determined with respect to the rails.
In that case the bullet will travel at very nearly 2X; for all practical purposes you can take it to be 2X. However, at very great speeds, near to that of light, the difference becomes noticeable.
As determined from the railway track, the measurement system of an incredible high speed train will be affected by the speed so that the bullet, although it looks like X as determined from the train, will add less than X to the speed of the train as seen from the railway track.
In the opposite direction the effect is also opposite: the bullet's speed will subtract with very slightly more than X from the speed of the train as determined from the railway track. For trains and bullets and usual requirements of precision, the the bullet's speed will be X-X=0.
If you want to deepen your understanding for very high speeds (or extreme precision), please ask for details in the relativity forum.
Well bullets are generally much faster than trains, so the bullet's velocity is going to be more than 2x. But basically, the velocity of the train will be directly added to the velocity of the bullet (or subtracted, if fired in the opposite direction). If the bullet is indeed just as fast as the train, then its velocity relative tot he ground will be 2x.
This is generally true until you start getting near the speed of light, but we needn't worry about that at everyday speeds.
Interesting, doesn't it also mean a person standing on the ground (train station) will see the bullet is hanging at one point in the air, not moving?
Even though the bullet is moving, the 'inertia speed' of the bullet will cancel the 'firing speed' of the bullet, as a result the bullet will appear to be hanging at one point in space. I can't even imagine this situation. Of course, all external disturbances must be eliminated.
As Lsos pointed out, a normal bullet goes much faster than a normal train. But yes, launch a projectile backwards out of a train with the same speed as the train is going, and it will fall straight down with respect to the ground.
...and curiously the gun will still kick the same due to the force needed to "stop" bullet from going the speed of the train. :smile:
On the contrary, it is not hard to imagine at all. In fact it is quite mundane.
The bullet does not hang at all, but falls to the Earth exactly as if someone was standing next to the rail and dropped it from their hand.
When you fire a gun horizontal to the Earth, the bullet, despite traveling at Mach speeds (or in your special case, only as fast as the train) falls to the ground exactly as if it is not moving at all. The X-component of its movement has no effect on the Y-component of its movement.Mythbusters demonstrated this by firing a gun and dropping a stationary bullet simultaneously. They hit the ground simultaneously.
  • · Replies 30 ·
  • · Replies 21 ·
  • · Replies 17 ·
  • · Replies 23 ·
  • · Replies 29 ·
