Curl is a measure of the tendency of a vector field
The discussion centers on the concept that the curl of the gradient of a scalar function, represented as ∇×grad(f), is always zero, indicating no rotational tendency in conservative vector fields. Participants explore the physical interpretation of this phenomenon, linking it to Stokes' theorem, which relates surface integrals of curl to line integrals around boundaries. The gradient represents the direction of steepest ascent, while the curl measures rotation; thus, when the gradient is defined, there are no closed loops to create rotation. The conversation emphasizes the mathematical foundation behind these concepts, suggesting that while intuition can be elusive, understanding the underlying principles is crucial. Overall, the relationship between gradients and curls in conservative fields is clarified through mathematical reasoning and the implications of Stokes' theorem.
zezima1
\nabla\timesgrad(f) is always the zero vector. Can anyone in terms of physical concepts make it intuitive for me, why that is so. I get that the curl is a measure of the tendency of a vector field to rotate or something like that, but couldn't really assemble an understanding just from that.
do you know stokes theorem, which for any vector field g is something like
<br /> \int_A \nabla \times \textbf{g} \cdot \textbf{dA} <br /> = \oint_{\partial A} \textbf{g} \cdot \textbf{dr} <br />
it converts an integral over a surface into an inetgral over the boundary. no conside g = \nabla f, any closed path integral will be zero - why?
also worth understanding conservative vector fields here
Physically, I'm not sure, but isn't mathematically enough ?
grad(f) is \nablaf so you take the vector product of a vector (\nabla) with one // to itself (\nablaf) so it will be 0 by definition of the vector product. (sorry if it does not help)
cheers..
i'm not especially sure on this, but looking at a drawing, i see that a vector field has rotation near a point x if that point is surrounded by closed loops. but then that means there isn't any directed gradient. conversely, if there is a direction for the gradient field, then there aren't any closed loops to measure rotation.
I know Stokes theorem, but that's just a mathematical theorem, which I by the end of the day then would want to understand intuitively. I do understand that a conservative field is a vector field, which is the gradient of a scalar field. It is then easily shown that the path integral between 2 points is independent of the road taken.
I just wanted the physical interpretation, and I haven't got it from those answers I'm afraid.
In other words: Further help needed! :)
The gradient 'sort of tells you how f is changing in a certain direction'
the curl, 'sort of tells you how much it changes in an orthogonal direction'
once you have limited the changes in the one direction of the grad, the variation that would go in the orthogonal direction of what is left (the curl of the grad) is, well, zero :)
well stokes theorem tells you the curl is similar to the path integral around a loop as you shrink the loop to zero length (orentated in a certain direction)
the gradient of a function is conservative, so the integral around any closed loop will be zero, and isf c is any point onteh closed loop, you can represent as follows
<br /> \int_A \nabla \times \nabla f \cdot \textbf{dA} <br /> = \oint_{\partial A} \nabla f \cdot \textbf{dr} = f(c)-f(c)=0<br />
To me this picture helps a lot to understand Stokes theorem
It just shows how if you want to find the circulation (RHS of stokes theorem) for the larger region, that's the same as adding up the contributions from the smaller rectangles because all the contributions from sides not on the boundary of the region cancel.
So to understand Stokes theorem you just need to understand why it would work for an infinitesimal rectangle. There I'm afraid you just need to write out the terms using a Taylor expansion and see that it works. Some things don't necessarily have a nice intuitive explanation.
