Current Measurement of Incident Proton ?
The discussion revolves around the measurement of proton current in cyclotron applications, particularly when the proton beam interacts with target materials such as water. Participants explore the methods of measuring current, the implications of protons being fully stopped in the target, and the role of Faraday cups and other detectors in this context.
  • Some participants note that the Faraday cup measures the flux of protons that do not interact with the target material.
  • Others suggest that to determine the flux interacting with the target, one must subtract the Faraday cup current from the total beam flux.
  • A participant questions how beam current is measured when protons are fully stopped in the target material, seeking references for established methods.
  • Concerns are raised about the clarity of diagrams presented, with one participant indicating that a control run without the target can help determine beam flux.
  • Another participant proposes using a small Faraday cup or detector before the target to sample flux, acknowledging that this method may slightly reduce the total flux.
  • There is a discussion about connecting current meters to the target body and whether positive charge carried by protons can flow through water if the protons stop there.
  • Some participants assert that if protons are absorbed in a solid target, the target becomes positively charged, which may draw electrons from connected wires.
  • One participant emphasizes that charge conservation principles apply, suggesting that current flow will utilize all available conductors and that a good connection to ground is essential for accurate measurements.
Participants express various viewpoints on the measurement techniques and implications of proton interactions with target materials. There is no consensus on the best method for measuring current or the effects of protons stopping in different materials.
Some limitations include the dependence on specific configurations of detectors and the assumptions made regarding charge conservation and current flow in different materials.
flied
The proton current in cyclotron are normally measured by Faraday Cup.
However, I do not understand that if there is target material for the proton beam.
Proton is fully stopped in the target material, for example, water.
How the current is measured if it did not hit anything else?
The faraday cup current is, then, telling you the flux that did not interact with the target.
If you want to know the flux that interacts with the target, then subtract the faraday current from the beam flux.
https://www.dropbox.com/s/pwkgce1d9rcj3ev/target.JPG
The beam is fully stopped in the target material (light blue) before reaching x.
I'm curious is this how the cyclotron that produce medical isotope measure beam current.
Please advise me that if there is any reference about it.
The diagram shows "a simple model for conductive heat transfer" and does not appear to have anything to do with protons.
One way to determine the beam flux is to do a control run without the target.
You can sample the flux during irradiation with a small faraday cup or other sort of detector in the beam before the target. This does remove some of the flux from the beam, but you either arrange for that to be small compared with the total flux or you take the measurement into account - a bit like using a thermometer to measure temperature (it removes some heat from the system being measured).
You can also get flux as a function of time during the control run ... this will help yu work out a strategy for dealing with the test run depending on what you hope to achieve. Projects like isotope manufacture only care about the mean flux since the test runs are long compared with beam fluctuations.
Of course - you could put a detector between the target and the water - that's only there for safety.
Note: the "typical system" in your diagram does not include a faraday cup - or any provision for detectors.
It describes a commercial-type setup - which will already have it's own arrangement of detectors.
Commercial-type setup like this one connect a current meter with the right (green) side of the target body.
A colleague explains to me that once the proton enter the target, by the law of charge conservation, positive electricity carried by the proton must flows through the current meter if it's connected to the target body (metal, conductor).
I'm just wondering can the positive electricity carried by the proton flows through water if the proton stops in the water ?
Yeah - if the proton is completely absorbed in a solid target, and nothing else happens, then the target becomes slightly positively charged. This draws an electron from the wire that is attached to the target ...
Presumably you could get water to do this. You'd certainly end up with more protons than electrons in the water ... and that charge has to go somewhere.
This is nothing to do with a Faraday cup.
This is simple charge conservation - and the fact that even a tiny unbalanced charge leads to a huge electric potential. Your target will be close to neutral all the time, so if protons go in, there are some electrons flowing in as well. Current flow will use all available conductors, but if you provide the "best" connection to ground (lowest resistance) and attach a current measurement you should get a good estimate of the proton current.
  • · Replies 16 ·
  • · Replies 25 ·
  • · Replies 25 ·
  • · Replies 54 ·
12K
