Current Source with two settings
A current source circuit is being designed to switch between 10 mA and 1.4 A for pulsing a laser diode. The suggestion is to use an enhancement mode MOSFET instead of a BJT to avoid issues with base current and beta inaccuracies. The proposed setup involves placing the diode at +5V, using a resistor to pull 10 mA when the transistor is off, and allowing 1.4 A when the transistor is on. The circuit operates as a current sink controlled by an op-amp, with specific voltage inputs to manage current flow. Heat management is crucial, necessitating heat sinks for the MOSFET and associated resistors.
jbord39
Hey all,
I am trying to create a type of current source to switch between 10 mA and 1.4 A at some frequency. I have an idea to use a BJT transistor as a variable resistor in a LM317 (or whatever the high current version is) but am not sure how to do it. Any suggestions? This circuit is to pulse a laser diode. Also, does this circuit have a name?
Thanks,
John
I make a lot of assumptions. i assume the laser diode is just a diode that has 1V drop when turn on. You have to tell me more info if I am not correct on the circuit. here is the quick I have for the first pass. I use an enhence mode MOSFET instead because I don't want to deal with the large base current and low beta that cause inaccuracy. basically I put the diode at +5V and turn it on by pulling current. I assume the turn on voltage is 1V so I use 400 ohm as R4 to pull 10mA when the transistor is off. When the transistor is on, it pull 1.4A so the 10mA just become insignificant. The circuit is a current sink control by the op-amp. The input should be 0V for turning the current sink off, 1.4V for pulling 1.4A. The accuracy depend on your requirement. You better put a heat sink on the MOSFET and the R3 because it will generate heat. R2 is to isolate the input capacitance of the MOSFET from the output of the op-amp ( that might cause instability) and C1 is to create a zero to guarante stability of the op-amp.
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
26K
