How High Can a 12V Battery Lift an 8.1 kg Mass with a 90% Efficient Motor?
The discussion centers on calculating the maximum height a 12V battery can lift an 8.1 kg mass using a motor with 90% efficiency. The battery provides 48 Watt-hours, equating to 172,800 Joules of energy. After accounting for the motor's efficiency, 155,520 Joules are available for work. Using the conservation of energy formula, the calculated height is approximately 1959.18 meters, which is deemed reasonable given the mass involved.
  • Understanding of electrical power equations (P = V * I)
  • Knowledge of energy conversion and efficiency calculations
  • Familiarity with the conservation of energy principle
  • Basic physics concepts related to mass and gravitational force
  • Explore advanced calculations involving motor efficiency and energy loss
  • Research the implications of using different battery capacities and voltages
  • Learn about practical applications of conservation of energy in mechanical systems
  • Investigate the limitations of theoretical calculations in real-world scenarios
Students in physics or engineering, electrical engineers, and anyone interested in the practical applications of energy conversion and mechanical work calculations.
pcandrepair
A fully energized 12V battery is rated as "4 Ampere-hours." Suppose this battery is connected to a motor that is 90% efficient at converting electrical to mechanical power. How high could this battery-supplied motor lift a 8.1 kg mass?
V = I*R
P = V*I
P = (I^2)*R
An amp-hour is how many amps a battery can supply for one hour.
Using the power equation:
P = (12V)*(4A*hr) = 48 Watt*hr
Since one watt-hr = 3600 Joules,
(48 W*hr)*(3600) = 1728 Joules
The motor is 90% efficient so,
1728 * .9 = 1555.2 Joules
I think the above is right (hopefully), but I'm not sure how to use the 1555.2 Joules to find the maximum height that this motor can lift the mass. Any help would be greatly appreciated. Thanks!
Power isn't in watt-hours, a watt hour is energy
Right idea still, 12V*4Ahr is 48 Watt*hr, but that itself equals 172800 joules
90% of that is straight up how much work the motor can do. Work...mass...looking for distance...
So, now at 90% of 172,800 J = 155,520 J
Using conservation of energy:
155,520 J = mgh
155,520 J = (8.1 kg)*(9.8 m/s^2)*(h)
h = 1959.18 m ?
This seems like a large value but reasonable because the mass is not that great.
Before I submit my answer, would you agree with using conservation of energy and the answer that I got?
111K
