DC Networks and Kirchoff's Laws
  • Thread starter Thread starter rikiki
    Dc Laws Networks
35 replies · 26K views
rikiki
Calculate the value of the current through the 12V battery shown in figure (attached).
V = IR
I1 = I2 + I3
I've calculated the current for the left hand loop, see below:
Loop 1:
E_1- E_2- V_1- V_2=0
E_1- E_2= V_1+ V_2
E_1- E_2=I(R_1+ R_2)
13-12= I (3+1)
1=4I
1/4=I
I=0.25A
I understand it's a process of doing the same to the right hand side and then subtracting the two sides? I'm just unsure as to when i should be adding the voltages and resistors and when i should be subtracting them.Is it related to the direction of the current and voltage potential? If anyone can help here it would be greatly appreciated. Thanks.
You have two loops which will influence each other in terms of voltage and current. So a single equation for one loop isn't going to capture the interplay.
What circuit analysis methods have you learned?
gneill, thanks for your help.
We've been shown the branch current method.
Okay. It looked as though you were attempting to apply Kirchhoff's Voltage Law (KVL) around a loop, but branch currents are good too! That boils down to Kirchhoff's Current Law (KCL), which states that the sum of the currents entering a given node of the circuit must equal the sum of the currents leaving that node.
Your circuit has three branches and two nodes. For the nodes, label the bottom horizontal conductor as "ground". Label the top horizontal conductor "Node A".
If you happened to known the voltage at node A (with respect to ground), VA, then you could calculate the current through each of the branches. For the leftmost branch, for example, you 'd have I = (VA - 13V)/R1. So how to determine VA? That's where Kirchhoff's Law comes in.
Assume that there's a voltage VA at node A. Write the equation for the sum of the currents leaving Node A for each branch connected to that node. I gave you the example for the first branch. Solve the resulting equation for VA. Once you know that voltage you can determine the current in each of the branches (including the one you're interested in).
Thanks again for your reply.
For the left hand loop I have:
+E1 - I3R3-E3-I1R1 = 0
19 - 3I3 - 12 - I1 = 0
-3I3 - I1 = 7
I2 = I1 - I3
I1 - I2 = 7
For the right hand loop I have:
+E2 - I3R3 - E3 - I2R2 = 0
14 - 3I3 - 12 - 2I2 = 0
-3I3 - 2I2 = 2
I1 = I2 + I3
I1 - 3I2 = 2
Multiply left hand side by four and add to right hand side ...
4I1 - 4I2 = 28
Left hand loop plus right hand loop ...
5I1 - 7I2 = 30
How can I know calculate the value of I1 and I2?
Where did the 19 come from? Doesn't E1 = 13V?
-3I3 - I1 = 7
I2 = I1 - I3
I1 - I2 = 7
-3I3 - 2I2 = 2
I1 = I2 + I3
I1 - 3I2 = 2
4I1 - 4I2 = 28
5I1 - 7I2 = 30
After you straighten out the voltage of E1, the first two equations that you wrote in bold constitute two equations in two unknowns. You can solve for both I1 and I2 with them. For example, if you subtract one equation from the other you should eliminate I1 and be left with an equation for I2.
Thanks for that, didn't even spot that.
So ...
I1 - I2 = 1
(I1 - I2) - (I1 - 3I2) = 1 - 2
2I2 = -1
I2 = -1 / 2 = -0.5A
Therefore if I1 - I2 = 1, I1 - -0.5 = 1
I1 = 0.5
If I1 = I2 + I3, 0.5 = -0.5 + 1
So current at E3 would be 1Amp
One problem I just spotted (should have caught it sooner) is that, according to your assumed current directions you should have I3 = I1 + I2. This is going to change your result, since you've written I1 = I2 + I3.
Here's the figure again with the assumed currents:
Ok thanks for seeing that. So,
If I2 = -0.5A
I1 - I2 = 1
Therefore I1 = 0.5
I3 = I1 + I2
I3 = 0.5 + -0.5
I3 = 0A
Current at E3 would be 0A?
You'll have to go back and rework the loop equations where you've used the current sum relationship. The current through E3 is not zero.
Thanks for all your help to date. I've come up with a final figure of 0.95A for I3. Does this seem right?
Unfortunately, no :cry: Something must have gone awry in the math.
How about one more attempt, from the beginning? I'll get things started, using the equations that you've written before:
KCL for top node: I3 = I1 + I2 ...(1)
KVL for left-hand loop:
13 - 3*I3 -12 - 1*I1 = 0
Replacing I3 using (1):
4*I1 + 3*I2 = 1 ...(2)
KVL for right-hand loop:
14 - 3*I3 - 12 - 2*I2 = 0
and using (1):
3*I1 + 5*I2 = 2 ...(3)
You should be able to solve (2) and (3) for I1 and I2, then use (1) to find I3.
I
Thanks for all your help.
So ...
4I1 + 3I2 = 1 1
3I1 + 5I2 = 2 2
Multiply 1 by 3
12I1 + 9I2 = 3
Multiply 2 by 4
12I1 + 20I2 = 8
(12I1 + 9I2) - (12I1 + 20I2) = 3 - 8
-11I2 = -5
I2 = -5 / 11
I2 = 0.45
4I1 + 3I2 = 1
4I1 + 3x0.45 = 1
4I1 + 1.35 = 1
4I1 = 1 - 1.35
= -0.35
I1 = -0.35 / 4
I1 = -0.0875
I3 = I1 + I2
= -0.0875 + 0.45
= 0.3625
= 0.4A?
Your method is good. You might want to keep a few more decimal places in intermediate values to prevent rounding errors from creeping into the final result.
Bravo.
Brilliant thanks for all your help.
I think your I2 should be
-0.4545 which changes your I1 to to 0.8409 giving I3 = 0.39 A.
This would affect your answer when working out the power dissipated on each resistor wouldn't it?
If i wanted to work out the power dissipated in each resistor. would i use P=I^2*R or P=I*V ??
Yes :smile:
Both are applicable depending upon what quantities you have to work with. There's also V2/R that'll work if you happen to have the voltage across the resistor.
ok so if i use P=I2R
with the folowing values for I:
I1 = -0.0875
I2 = 0.45
I3 = 0.4
i get:
PR1 = -0.08752 * 1 = -0.00766 Watts
PR2 = 0.452 * 2 = 0.405 Watts
PR3 = 0.42 * 3 = 0.48 watts
but if i use the other formula P=I*V
i get:
PR1 = 0.0875 * 13 = 1.1375 watts
PR2 = 0.45 * 14 = 6.3 watts
PR3 = 0.4 * 12 = 4.8 watts
which is correct?
I1 = -0.0875
I2 = 0.45
I3 = 0.4
As was pointed out by charger9198 in a previous post, there seems to be some issue with the calculated values for the currents. I've just taken a look at the circuit and I can see that the values are not those given above :frown:
You should recalculate the currents before moving forward.
i get:
i get:
which is correct?
Well the second set is definitely incorrect because the voltage you need to use is the potential that appears across each resistance. This will NOT be the values of the individual cells in the branches; it will be the voltage drop due to the current passing through a given resistor.
ok so i re calculated the current as follows:
I1 = 0.09091 A
I2 = 0.45455 A
I3 = 0.36364 A
do these values look more accurate?
I1 = 0.09091 A
I2 = 0.45455 A
I3 = 0.36364 A
Yes, their magnitudes look okay.
i now get:
PR1 = -0.090912 * 1 = -0.008265 Watts
PR2 = 0.454552 * 2 = 0.4132 Watts
PR3 = 0.363642 * 3 = 0.3967 watts
They should all be positive values. I2 will be positive no matter the sign of I. Energy being dissipated as heat in a resistor doesn't care which way the current flows :smile:
yes ok I see you point,
PR1 = -0.090912 * 1 = 0.008265 Watts
they seem very small values to me
Small currents and small resistances yield small power dissipations. In a large system they can still add up!
How do we get a negative current in I1? does this mean the direction of current is opposite to that shown on the diagram and does the law now change to I3 = I1 - I2?
Nothing changes. The equations to solve the circuit were based upon assumed current directions that may or may not turn out to be correct assumptions. No matter, the math takes care of such things. If a current that was thought to flow one way but turns out to flow in the opposite direction, it will end up with a negative value. No big deal. All the equations still apply exactly as written, just use the values obtained.
i understand up to this point...
So ...
4I1 + 3I2 = 1 1
3I1 + 5I2 = 2 2
Multiply 1 by 3
12I1 + 9I2 = 3
Multiply 2 by 4
12I1 + 20I2 = 8
-11I2 = -5
I2 = -5 / 11
I2 = 0.45
4I1 + 3I2 = 1
4I1 + 3x0.45 = 1
4I1 + 1.35 = 1
4I1 = 1 - 1.35
= -0.35
I1 = -0.35 / 4
I1 = -0.0875
I3 = I1 + I2
= -0.0875 + 0.45
= 0.3625
= 0.4A?
I have follewed up this point quite clearly, however I don't understand the reason why we have to multiply equation 1 by 3 ? If somebody could explain this too me or even send me a link where I can understand why.
