DC to AC Inverter Design Difficulty
The discussion centers on the challenges of designing a DC to AC inverter to power an AC motor using a fuel cell with MATLAB. The primary issue is the output current of the DC converter dipping below zero, which triggers a 'ln of -ve number' error in the fuel cell. The user attempted to mitigate this by adding an inductor between the inverter and converter, but this resulted in a significant voltage drop. The main question posed is how to prevent the output current from dipping below zero without reducing the inverter's voltage.
  • Understanding of inverter design, specifically H-bridge inverters.
  • Familiarity with MATLAB for simulation of electrical systems.
  • Knowledge of fuel cell operation and its electrical characteristics.
  • Basic principles of AC motor synchronization with inverter output.
  • Research H-bridge inverter configurations and their applications in AC motor control.
  • Explore MATLAB simulation techniques for modeling inverter circuits.
  • Investigate methods to stabilize output current in DC-AC converters.
  • Learn about the impact of inductors on inverter performance and voltage regulation.
Electrical engineers, power electronics designers, and anyone involved in inverter design and simulation for AC motor applications.
Scorael
Hey Guys,
I'm having trouble designing an inverter to power an ac motor using a fuel cell with MATLAB. With the inverter, the output current of the DC converter dips below 0 and the fuel cell does not like that at all because it causes a 'ln of -ve number' error.
I have tried placing an inductor between the inverter and converter, which works but causes the inverter output voltage to dip about 1000 times way below the required voltage.
So the question is: how do I prevent the output current of the converter from dipping below 0 without stepping down the voltage of the inverter?
Thanks in advance for any help given
Scorael said:
Hey Guys,
Welcome to the PF, Scorael. Are you using an H-bridge inverter to power the AC motor? How are you sync'ing the AC output with the AC input requirements of the motor?
Can you post your MATLAB simulation setup and results? That would make it easier for the MATLAB and simulation experts here to help you with suggestions.
  • · Replies 39 ·
