Decoupling Capacitor for a PCB Track
2 replies · 3K views · last reply
Weaver
Circuit schematic of a humidistat: two type K thermocouples (dry and wet) feed an ADA4528 chopper opamp A1, whose output goes via R1 and R2 to an MBED LPC1768 analogue input Ain; MBED Dout drives IRL530N MOSFET Q1 switching ultrasonic fogger X1 from a 24V supply regulated to 5V by a 7805.
Worksheet of numeric answer fields with questions on thermocouple voltage, ADC gain, bias current resistors, PCB track impedance ripple, LSB size, decoupling capacitance, gate switching time and gate drive frequency, with units shown beside each blank.
3. The Attempt at a Solution [/B]
Currently stuck on the question relating to the value of capacitance across X1/Q1 to reduce the voltage to 1 LSB
I have calculated the voltage of the 1LSB to be 0.8507 mV
ADC Range/Resolution 3.3V/2^12
I have also calculated the voltage across the PCB track to be 10 + 64pi mV
Z = 0.1 + j2pi(1.6 x 10^6)(0.2 x 10^-6)
= 0.1 + j16/25 pi
V = IZ
V = (100 x 10^-3)(0.1) + j16/25 pi)
V = 10 + j64pi mV
For the capacitance, can I just used an equation I have seen before,
C = I/(Vripple x f)
with Vripple as 0.8507 mV
or
Do I have to calculate the parallel impedance of a the PCB track with a capacitor and find a value for C such that the magnitude of the voltage with 100 mA is less than 0.8507 mV?
  • Circuit schematic of a humidistat: two type K thermocouples (dry and wet) feed an ADA4528 chopper opamp A1, whose output goes via R1 and R2 to an MBED LPC1768 analogue input Ain; MBED Dout drives IRL530N MOSFET Q1 switching ultrasonic fogger X1 from a 24V supply regulated to 5V by a 7805.
  • Worksheet of numeric answer fields with questions on thermocouple voltage, ADC gain, bias current resistors, PCB track impedance ripple, LSB size, decoupling capacitance, gate switching time and gate drive frequency, with units shown beside each blank.
trurle said:
C=(Iripple*Ton)/Vmax=0.1A*(1/3.2)*1us/0.85mV=37uF
Great! Thank you very much!
