Definite integrals with +ve and -ve values
The discussion centers on calculating definite integrals of functions with both positive and negative values, specifically focusing on the sine function. Participants clarify that to find the total area under the sine curve, one must consider the intervals where the function is above and below the x-axis. The RMS (root mean square) value is introduced as a potential alternative for measuring average values, but it is established that the integral of the absolute value of sine, $$\int_a^b |sin(x)|\,dx$$, is not equivalent to the RMS calculation $$\sqrt{\int_a^b f(x)^2\,dx}$. The necessity of breaking down limits for accurate area calculation is emphasized.
  • Understanding of definite integrals and their properties
  • Familiarity with the sine function and its graphical representation
  • Knowledge of root mean square (RMS) calculations
  • Basic calculus concepts, including integration techniques
  • Study the properties of definite integrals involving piecewise functions
  • Learn about the application of RMS in electrical engineering contexts
  • Explore the concept of rectified functions and their integrals
  • Investigate numerical methods for approximating integrals of complex functions
Students and professionals in mathematics, physics, and engineering who are looking to deepen their understanding of integral calculus, particularly in the context of functions with both positive and negative values.
HuskyLab
I understand that if you have a function in which you want to determine the full (i.e. account for positive and negative values) integral you need to break down your limits into separate intervals accordingly.
Is there any way in which you can avoid this or is it mathematically impossible? If so, can someone explain to me why you can't?
I thought about trying to incorporate a rectified sine wave (abs(sinx) as an alternative but is such a function applicable/usable (is it even considered continuous)? How do you represent and integrate such a function algebraically?
Thanks.
It depends what you mean by the full integral.
Perhaps what you are searching for is the RMS (root mean square) value, which is
$$\sqrt{\int_a^b f(x)^2\,dx}$$
This is used for instance as a measure of average voltage and current in AC circuits, since the simple integral will be close to zero because the positives and negatives cancel each other out.
So squaring the function will rectify it and then the subsequent values calculated in the integral of interval a->b then rooted will be the same as:
Is that correct?
So I just calculated it myself and they are not equivalent.
$$\int_a^b |sin(x)|\,dx \neq \sqrt{\int_a^b f(x)^2\,dx}$$
Is that correct?
But these are equal:
$$\int_a^b |sin(x)|\,dx = \int_a^b \sqrt{\sin^2(x)}\,dx$$
for the reason that ##|x| = \sqrt{x^2}##, by definition.
Yeah, that makes sense. Do you know of any way in which you can calculate the total area under a sine function without breaking down the limits or does the question itself not make sense? Integrating something akin to a rectified sine wave? $$|sin(x)|$$
It depends on whether the question asks for the integral, say, ##\int_a^b \sin(x)dx## or the area between the graph of y = sin(x) and the x-axis between x = a and x = b. If the question asks for area, you need to consider the intervals where the graph lies above the x-axis and those intervals where the graph is below. Changing to absolute value doesn't seem like a reasonable shortcut to me, as you still need to replace |sin(x)| by sin(x) on the intervals where sin(x) >= 0, and to -sin(x) on the intervals where sin(x) < 0.
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 18 ·
