Definition of inertial reference frames
5 replies · 3K views
throneoo
What is the definition of an inertial frame ? I've read that Inertial frames are reference frames in which Newton's first law applies (i.e.bodies subject to zero net external force moves at constant velocity) , however Newton's 1st law itself is only valid under inertial frames. I find it weird because that would make inertial frames circularly-defined.
some texts define it without direct reference to "Newton's 1st law", defining as "frames in which an object subject to no net external force moves in constant velocity" , but I don't think that addresses the issue at all. Are there any alternative definitions?
It doesn't make it circularly defined. Newton came up with this idea: an object's velocity will not change unless there is some net force on the object. We define non inertial frames as frames where this idea doesn't apply. We have a law, and we have a name for situations in which the law doesn't apply.
Alternately, you could simply say a noninertial frame is a frame of reference that undergoes no acceleration.
All of physics is based on connected definitions like this. For example: Charge is what is affected by electric field. The electric field is what affects charges. It's not circular, but merely defining two terms at the same time, based on their relation.
Should this be an 'inertial' frame and not a 'noninertial' frame?
Yes, that's the non-relativistic definition. The feeling of weirdness is understandable but mechanics is not wrong because of this. It is just that Newton's laws can be applied with lot of success in some frames and with little success in others.
For example, motion of the Moon around the Earth can be well analyzed with Newton's laws and with assumption that Earth is an origin of an inertial frame (axes pointing to distant stars). However, the motion of the Sun around the Earth cannot be successfully analyzed this way. Instead, one may describe motion of the Earth from the frame centered in the Sun (with axes pointing to distant stars) and then translate the results to the frame of the Earth.
Originally, Newton formulated his laws with respect to absolute space - there was no concept of inertial frame. However, absolute space has not been detected, has been frowned upon and Newton's laws were reformulated with inertial frames instead. This has made the system logically OK but how to ascertain whether system is inertial is not easy. There is no way to ascertain exact inertialness of a frame - there may and usually always are discrepancies. Often these are negligible, so we simplify and say Earth is inertial system, or solar frame is inertial system based on the question at hand. We use Newton's laws in the frame they apparently do work well and pronounce that frame as inertial enough.
