Degree of freedom definition help
The discussion focuses on the challenges of understanding the concept of degrees of freedom (DOF) and constraints in mechanics. The original poster expresses frustration with the limited resources available, particularly on Wikipedia, regarding the definition of DOF. They seek additional links and clarification on the definition provided, which outlines the six degrees of freedom for a rigid body in three dimensions. Participants suggest looking into kinematic pairs for further understanding of constraints. The conversation highlights a need for more comprehensive educational materials on these topics.
roshan2004
I have been trying to learn degree of freedom and constraints by myself. However the content of these materials are very limited especially of Degree of freedom. I tried to check about these materials on the wikipedia too, but disappointed with the content about it. Can anyone provide me the links regarding these topics especially of degree of freedom.
What is wrong with this definition from http://en.wikipedia.org/wiki/Degrees_of_freedom_(mechanics)" :
In mechanics, degrees of freedom (DOF) are the set of independent displacements and/or rotations that specify completely the displaced or deformed position and orientation of the body or system.
In three dimensions, the six DOFs of a rigid body are sometimes described using these nautical names:
Moving up and down (heaving);
Moving left and right (swaying);
Moving forward and backward (surging);
Tilting forward and backward (pitching);
Turning left and right (yawing);
Tilting side to side (rolling).
As for the constraints, look for http://en.wikipedia.org/wiki/Kinematic_pair" . I think it will help you.
[URL]http://web.mit.edu/mecheng/pml/spec_config-8.jpg[/URL]
Thread 'What is the pressure of trapped air inside this tube?'
As you can see from the picture, i have an uneven U-shaped tube, sealed at the short end. I fill the tube with water and i seal it. So the short side is filled with water and the long side ends up containg water and trapped air. Now the tube is sealed on both sides and i turn it in such a way that the traped air moves at the short side. Are my claims about pressure in senarios A & B correct? What is the pressure for all points in senario C? (My question is basically coming from watching...
  • · Replies 31 ·
