Denominator in cosmological constant term in Newtonian gravity
Messenger
In General relativity: an introduction for physicists, the authors derive Newtonian gravity from the EFE, but then they also give a short statement that inserting in the cosmological constant derives down to:
<br /> \vec{g}=-\nabla\Phi=-\frac{GM}{r^{2}}\hat{\vec{r}}+\frac{\Lambda c^{2}r}{3}\hat{\vec{r}}.<br />
I don't see how they end up with a 3 in the denominator. Probably am missing something simple. Any help?
Sure, the factor of 1/3 comes from integrating Λr2. :smile:
Seriously, I don't think you can expect an intuitive motivation for each factor of two or three. Intuition is great for order of magnitude estimates, or determining minus signs, but to get right down to an actual numerical factor you usually just need to plow through the math.
One of Einstein's equations for spherical symmetry happens to be d(r g00)/dr = 1 - Λr2, and the solution for g00 has a 1/3 in it.
Heh, I wish it was just the integration (and maybe it just is :redface:). Anyway, I should probably post how I think it is done here and maybe someone can pinpoint where my confusion lies (or more likely I will just end up embarrassing myself :-p).
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
