MHB You're welcome, happy to help!
  • Thread starter Thread starter Joppy
    Orbits Periodic
Periodic orbits are considered 'dense' if, for any point and any ε-neighborhood, there exists at least one periodic point within that neighborhood. Uniqueness of these periodic points is not required; multiple points can belong to the same orbit and still satisfy the density condition. Even if every neighborhood contains points from the same periodic orbit, the orbits are still deemed dense, as this condition is stronger than merely having a union of periodic orbits being dense. However, in the context of $\mathbb{R}^n$, a single periodic orbit cannot be dense, which differs in more general metric spaces. This discussion clarifies the nature of density in periodic orbits within dynamical systems.
Joppy
MHB
Loosely speaking, we say that periodic orbits are 'dense' if given any $\epsilon$-neighborhood, there exists at least one periodic point in that neighborhood for any $\epsilon > 0$.
Is there any requirement for these periodic points to be unique?
For example, what if every neighborhood contains a periodic point (that we know about) which is part of the same periodic orbit. Do we still say that orbits are dense? Or are they dense in a trivial sense.
Thanks!
Mathematics news on Phys.org
For concreteness, is your setting a discrete dynamical system represented by an iterated map $f$ on $\mathbb{R}^n$ or, more generally, on some complete metric space? It does not matter that much, though: For a flow, the ideas are similar.
Yes, periodic orbits of $f$ are dense if given any point $\mathbf{x} \in \mathbb{R}^n$ and any $\epsilon > 0$, there exists a periodic point $\mathbf{y} \in \mathbb{R}^n$ of $f$ (of course $\mathbf{y}$ lies on some periodic orbit) such that $\|\mathbf{x} - \mathbf{y}\| < \epsilon$. In other words, the set consisting of the union of all periodic orbits of $f$ is dense in $\mathbb{R}^n$ in the ordinary sense.
No, quite the opposite. Let $\mathbf{x}$ and $\epsilon > 0$ be given. Assume that $\mathbf{x}$ itself is not periodic. (This is always possible, unless the whole phase space consists of periodic points.) Suppose it happens that $\mathbf{y}$ is the unique periodic point in the $\epsilon$-ball centered at $\mathbf{x}$. Then the ball centered at $\mathbf{x}$ with radius $\frac{1}{2}\|\mathbf{x} - \mathbf{y}\| > 0$ does not contain any periodic points, which contradicts density.
Sure we still say that periodic orbits are dense. In fact, the property you mention now is stronger than what you mentioned at the beginning: Now, one periodic orbit has to do the job of being dense in the phase space, whereas before it was only required that all periodic orbits together form a dense union.
Addition: Note that for the case of $\mathbb{R}^n$, a single periodic orbit cannot be dense. (In the general metric case, it is different.)
Thanks a lot for the informative response, and apologies for my late one!
Not quite $\mathbb{R}^n$, although I was assuming this in my question to make sure I see the other half of the story..
This makes sense! An easy to understand argument indeed. Thanks.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
