Dense set vs no isolating points
  • Context: Graduate
  • Thread starter Thread starter SchroedingersLion
    Points Set
3 replies · 2K views
SchroedingersLion
TL;DR
Differences between two concepts.
Greetings,
could you commend or correct the following:
A dense subset ##X## of a set ##Y## is a set such that in each environment of ##y\in Y##, there is at least one element ##x\in X##. In other words, the elements of ##Y## can be approximated arbitrarily well by elements in ##X##.
A set with no isolating points is a set such that in each environment of ##a\in A##, there are other elements of A.
Are dense subsets automatically sets with no isolating points?
Simple example, ##\mathbb{Q}## is dense in ##\mathbb{R}##, so in each environment of ##x\in \mathbb{R}## there is at least one element ##\in \mathbb{Q}##. But take an ##x\in \mathbb{Q}##. Are there other rationals in each environment of a rational?SL
Yes there are other rationals in each neighborhood of a rational! Given a rational ##q\in \mathbb{Q}##, simply consider ##q+\frac{1}{n}## where ##n## is a sufficiently large natural number (basically this is rewording that ##q+\frac{1}{n}\to q##).
Your definition of dense set seems ok to me. This is equivalent with saying that the closure of ##X## is ##Y## or that ##X## intersects every open set of ##Y##.
A dense set can evidently have isolated points. Consider the space ##Y = [0,1]\cup \{2\}## (with the subspace topology inherited from the usual topology). Then ##X=Y## is dense in itself (trivially) but ##2## is isolated in ##X## since ##\{2\}## is an open set.
Thank you Math_QED,
so while ##\mathbb{Q}## is dense in ##\mathbb{R}## and has no isolating points, it is generally not true that dense subsets have no isolating points.
SchroedingersLion said:
Thank you Math_QED,
Exactly.
