Density matrix for bell states
6 replies · 16K views
pleasehelpmeno
Hi
I have three states (I believe bell states) and want to find the density matrix, am I right in thinking:
1) [itex]\frac{|00> + |11>}{\sqrt{2}} \rightarrow \rho = \left( \begin{array}{cc}<br /> \frac{1}{\sqrt{2}} & 0 \\<br /> 0 & \frac{1}{\sqrt{2}} \\<br /> \end{array} \right)[/itex] (because it is pure)
2) [itex]\frac{|00> - |11>}{\sqrt{2}} \rightarrow \rho = \left( \begin{array}{cc}<br /> \frac{1}{\sqrt{2}} & 0 \\<br /> 0 & \frac{1}{\sqrt{2}} \\<br /> \end{array} \right)[/itex] (because it is pure)
3) [itex]\frac{|01> + |01>}{\sqrt{2}} \rightarrow \rho = \left( \begin{array}{cc}<br /> \frac{1}{\sqrt{2}} & \frac{1}{\sqrt{2}} \\<br /> \frac{1}{\sqrt{2}} & \frac{1}{\sqrt{2}} \\<br /> \end{array} \right)[/itex] (because it is mixed)
Shouldn't the density matrix be 4x4? The first one should be something like
[tex] \begin{pmatrix}<br /> 1 & 0 & 0 & 1\\<br /> 0 & 0 & 0 & 0\\<br /> 0 & 0 & 0 & 0\\<br /> 1 & 0 & 0 & 1<br /> \end{pmatrix}[/tex]
The others then analogously, but a 100% I am not certain, because looking at the Schmidt-coefficients, they are not all the same (2 are actually 0) as required for a maximally entangled state. Anyone can solve this issue?
You get the density matrix of the composite system by writing out ρ= |ψ><ψ| for your states. This is a 4x4 matrix.
If you want to get the reduced density matrix of one subsystem,you have to trace over the other system. You then get a 2x2 matrix.
PS: Why do you think that the third state is not pure? Every ket corresponds to a pure state. You seem to have some fundamental misunderstanding. You need to give more details about your calculations.
spookyfw said:
[...] looking at the Schmidt-coefficients, they are not all the same (2 are actually 0) as required for a maximally entangled state.
You need only as many coefficents as the dimension of the Hilbert space of the smaller subsystem. Here, we have two 2-dimensional Hilbert spaces, so we need two coefficients.
Please could you describe the difference between a pure and a mixed state?
I am also unclear as to how to calculate the density matrix, could you give me a simple example, I can't see why [itex]\sum_i |\psi_i><\psi_i|[/itex] would give a 4x4 matrix.
Would you have to decompose [itex]|00>[/itex] into |0>|0> and then into,
(A|0> + B|1>)Tensor-product(C|0>+D|1>)? I am a bit confused
A pure state can be a linear combination of other pure states. This is the quantum mechanical superposition.
For a pure state |ψ> we simply chose this state |ψ> to construct the density matrix
ρ = |ψ><ψ|
As you can see you have ρ2 = ρ, so ρ is a projector (here we do not care whether there are other states, e.g. u and v, which can be combined via a linear superposition to get ψ).
A mixed state is always described via a density matrix which is not a projector.
For a mixed state, in a basis where the density matrix is diagonal, you have two or more states with non-vanishing probability. So for two orthogonal states contributing to a density matrix you have
ρ = p|u><u| + (1-p)|v><v|
Note that for a diagonal density matrix the trace of the probailities must be = 1.
Testing whether ρ is a projector you find
ρ2 = p2|u><u| + (1-p)2|v><v| ≠ ρ
The probabilities p and (1-p) in ρ are classical probabilities, not related to the quantum mechanical superpositions. So if you would construct ψ from u and v using quantum mechanical superpositions you get the pure state as described above.
Have you calculated [itex]\rho = |\psi><\psi| = \frac{1}{2}(|00> + |11>)(<00|+<11|)[/itex]? (First example from you)
ρ has 16 entries which are the coefficients in front of the 16 possible combinations |ij><kl|. Most of them are zero, but 4 are non-zero. If you arrange them in matrix form, you are done.
No decomposing of |ij> is required, because we are now dealing with the combined state space of two quibits. There are states which can't be decomposed and these are the entangled states.
