Derivation of exact differential
  • Context: High School
  • Thread starter Thread starter kidsasd987
    Derivation Differential
The discussion centers on the derivation of the exact differential of a scalar function f, expressed as ∇f⋅dr=Σ∂ifdxi. The integration of this equation leads to ∫df=∫{Σ∂ifdxi}, highlighting the linearity of integration. The confusion arises from the interpretation of integrating partial differentials and the resulting constants. The key takeaway is that while each partial derivative contributes to the gradient, the final scalar function is not merely the sum of these derivatives but rather a unique function that encapsulates all contributions.
  • Understanding of vector calculus and differential operators
  • Familiarity with scalar functions and their gradients
  • Knowledge of integration techniques in multivariable calculus
  • Basic concepts of partial differentiation
  • Study the properties of the gradient operator in vector calculus
  • Learn about the implications of linearity in integration
  • Explore the relationship between partial derivatives and scalar functions
  • Investigate examples of exact differentials in multivariable functions
Mathematicians, physics students, and anyone studying multivariable calculus who seeks clarity on the concepts of exact differentials and gradient operations.
kidsasd987
Exact differential of a scalar function f takes the form of
∇f⋅dr=Σ∂ifdxi (where dr is a vector)
f:R->Rnand I am not sure why this equation is valid in the sense that if we integrate the equation,
∫∇f⋅dr=∫{Σ∂ifdxi}
∫df=∫{Σ∂ifdxi}
the above equation is true because integration is a linear operator, and if we think of R.H.S only,
∫{Σ∂1fdx1}+∫{Σ∂i≠1fdxi≠1}
=f+c(x2,x3...,xn)+∫{Σ∂i≠1fdxi≠1}
and if we think of each integration of differential w.r.t variable x1,x2,x3 and so on, it should generate f+c respectively as the result of each integration.
therefore R.H.S has to be
nf+C(x1,x2,x3...,xn) but according to textbook, it says we don't add up each integration but we compare them to eradicate constants and "merge" each equation to one right answer, f.
I am a little bit confused about how to interpret the integration within the quotation mark ∫df="∫"{Σ∂ifdxi} because it seems it is linearly applied to each of partial differential, but does not spit out nf(n number of partial differentials so there must be n number of integrations on them so adding them up would give nf+C(x1,x2,x3...,xn)
Please enlighten me. I would really appreciate
As you noted, the gradient operator takes a scalar in R and gives a vector in $$R^n$$ and each derivative of f in the sum gives a component of the resulting vector. The key here is that the differential operators all act on f and they act differently. For instance you can have f = xy, taking the 2D gradient gives df/dx = y and df/dy = x. The scalar function f that produces the derivative is not the sum of derivatives which is 2*xy but is instead f = xy. This is what the book means by compare, eradicate and merge. You know there must be an xy term from integrating the x derivative and similarly for the y derivative but the result is not their sum in this case, you can test this by differentiating it again to see if it gives the same gradient.
  • · Replies 46 ·
