Derivation of the atomic form factor
The atomic form factor is defined as an integral involving electron density and a reciprocal lattice vector. The transition from the first equation to the second involves integrating over spherical coordinates, simplifying the expression under the assumption of spherical symmetry in the electron distribution. The notation d(cos α) is used to facilitate integration over angles, specifically transforming the polar angle θ into a cosine function. The integration limits from -1 to 1 correspond to the full range of the cosine function, which is necessary for evaluating the integral in spherical coordinates. Understanding these concepts is crucial for grasping the derivation and application of the atomic form factor.
mjordan2nd
My book defines the atomic form factor as
\int dV n_{j}(\vec{r})e^{-i \vec{G} \bullet \vec{r}}.
where n(r) is the electron density of the jth atom at r, and G is the reciprocal lattice vector. It says the above expression is equal to
2 \pi \int dr r^{2} d(cos \alpha) n_{j}(r) e^{-iGr cos \alpha}
in the case that the electron distribution is spherically symmetric where alpha is the angle between the reciprocal lattice vector and r. I don't understand how the author goes from the first equation to the second. In fact, I'm not sure I'm comfortable with this d(cos) notation at all. If someone could point me to a site where I could read up about that, I would appreciate it. The author then proceeds to integrate d(cos) from -1 to 1. Why he does this is unclear to me as well. Any help is appreciated.
The integral is done in spherical coordinates.
The z axis is taken along the direction of the G vector so the angle between r and G si theta (the polar angle).
The volum element in spherical coordinates is
dV=r^2 sin(theta) dr d(theta) d(phi)
The author writes sin(theta)d(theta) as d(cos theta).
n(r) is asumed to have spherical symmetry here so it depends on the r (magnitude, not vector) only.
For more on sperical coordinates, you can see this, for example:
http://en.wikipedia.org/wiki/Spherical_coordinate_system
Thread 'Unexpected irregular reflection signal from a high-finesse cavity'
I am observing an irregular, aperiodic noise pattern in the reflection signal of a high-finesse optical cavity (finesse ≈ 20,000). The cavity is normally operated using a standard Pound–Drever–Hall (PDH) locking configuration, where an EOM provides phase modulation. The signals shown in the attached figures were recorded with the modulation turned off. Under these conditions, when scanning the laser frequency across a cavity resonance, I expected to observe a simple reflection dip. Instead...
