nakurusil said:
[tex]m_1u_1+m_2u_2=(m_1+m_2)V[/tex] (1)
from the point of two different frams S and S' in relative motion with speed V.
In frame S' the two masses are moving at speed +u' and -u' respectivelly.
Using the speed composition law, Tolman shows that :
[tex]u_1=(u'+V)/(1+u'V/c^2)[/tex] (2)
[tex]u_1=(-u'+V)/(1-u'V/c^2)[/tex] (3)
Substituting (2)(3) into (1) he gets:
[tex]m_1/m_2=(1+u'V/c^2)/(1-u'V/c^2)[/tex] (4)
Since he showed earlier that:
[tex]1+u'V/c^2=\sqrt(1-u'^2/c^2)*\sqrt(1-V^2/c^2)/\sqrt(1-u^2/c^2)[/tex]
substituting in (4) he gets:
[tex]m_1/m_2=\sqrt(1-u_2^2/c^2)/\sqrt(1-u_1^2/c^2)[/tex] (5)
If one takes [tex]u_2=0[/tex] then [tex]m_2=m_0[/tex] (the "rest mass"), [tex]u_1=u[/tex] and (5) becomes:
[tex]m_1=m(u)=m_0/\sqrt(1-u^2/c^2)[/tex] (6)
Very ugly and useless.
I had to think for more than an hour to make sense of this calculation, so I'll try to explain it to those who gave up after running into the same problems.
S' is the frame where the speeds are u' and -u'. S is an arbitrary frame for the moment. We will make a specific choice later.
V = the velocity of S' in S
u1 = the velocity of object 1 in S
u2 = the velocity of object 2 in S
I'm using units such that c=1.
The addition of velocities formula yields (2) and (3), except that there's a typo in (3). The LHS should say u2.
[tex]u_1=\frac{u'+V}{1+u'V}[/tex]
[tex]u_2=\frac{-u'+V}{1-u'V}[/tex]
Now suppose that the two objects will stick to each other. Let's choose their masses to be the same. Then the speed of the two objects in S' will be 0. This means that the speed in S' will be V.
Now suppose that relativistic conservation of momentum in frame S can be expressed as
[tex]m(u_1)u_1+m(u_2)u_2 = (m(u_1)+m(u_2))V[/tex]
where this "relativistic mass" is assumed to be a function of velocity. m(0) is the rest mass. This is (1) expressed in a more transparent way. Note that this wouldn't hold if we hadn't already assumed that the two rest masses are the same.
Our goal is to determine the form of the function m.
First solve (1) for m(u1)/m(u2). The result is
[tex]\frac{m(u_1)}{m(u_2)}=\frac{V-u_2}{u_1-V}[/tex]
Then insert the results (2) and (3) (mind the typo though) into this, and simplify. The result is (4).
[tex]\frac{m(u_1)}{m(u_2)}=\frac{1+u'V}{1-u'V}[/tex]
Now choose the frame S so that u2=0. This turns (3) into u'=V. Let's write u instead of u1, and [itex]m_0[/itex] instead of m(0). Equation (4) now takes the form
[tex]m(u)=m_0\cdot\frac{1+V^2}{1-V^2}=m_0\cdot\frac{1+V^2}{1-V^2}[/itex]<br />
<br />
We want the result as a function of u, so we use the result u'=V in (2), and solve for V. The result is<br />
<br />
[tex]V=\frac{1+\sqrt{1-u^2}}{u}[/tex]<br />
<br />
It should be easy from here, but for some reason I don't see how to do the simplification. Anyone else feel like finishing this one off?<br />
<br />
<b>Edit:</b> I got it. <br />
<br />
The result u'=V turns (2) into<br />
<br />
[tex]u=\frac{2V}{1+V^2}[/tex]<br />
<br />
I found a way to use this.<br />
<br />
[tex]\frac{1+V^2}{1-V^2}=\frac{1+V^2}{1+V^2-2V^2}=\frac{1}{1-\frac{2V^2}{1+V^2}}=\frac{1}{1-uV}=\frac{1}{1-(1+\sqrt{1-u^2})}=\frac{1}{\sqrt{1-u^2}}=\gamma[/tex][/tex]
