Derivative of a multi-variable function
The discussion revolves around the differentiation of a multi-variable function, specifically the expression (2nb^{rx}+n)^{k}. Participants express confusion about which variable to differentiate with respect to, particularly in cases where multiple variables are present. It is suggested that in some cases, only one variable may be treated as a variable while others are constants. In scenarios involving both x and y, partial derivatives are recommended, and implicit differentiation may be necessary if y is considered a function of x. The conversation highlights the importance of understanding the context of variables in differentiation.
raining
The question asks to differentiate (2nb^{rx}+n)^{k}
However, the problem is that it doesn't specify with respect to which variable should the derivative be taken.
When the question asks to differentiate, does it mean that we should take the derivative for each and every variable, one by one?
I'm guessing that there is only one variable here - x - and all other letters represent constants.
Ok, then what about in a question such as ysin(x)+e^{x^{2}y}=\sqrt{x+y}
This is what is confusing me.
In this case will both x and y be variables?
In that case I would suggest the partial derivatives.
Although, strictly speaking, the fact that the partial derivatives exist at a point does not prove that the fuction is "differentiable"- but the fact that they are continuous does. To be perfectly correct, the "derivative" of a two variable function is the linear transformation from R2 to R given by taking the dot product of \nabla f\cdot <x, y> and so can be represented by \nabla f.
Perhaps it is an implicit differentiation exercise with y understood to be a function of x defined implicitly. Then you would calculate ##\frac{dy}{dx}## implicitly.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
