Derivative of an expoential within an exponential
15 replies · 3K views
sprint
[SOLVED] derivative of an expoential within an exponential
help. i need help on finding the derivative of an exponential within an exponential
d/dx of e^(e^4x)
d/dx of e^(e^4x)
d/dx of e^(e^4x)
i don't know how to attempt this cause the function I am interested is in the power of e
We know that the derivative of an exponential is simply the exponential times the derivative of power term, right?
[tex]\frac{d}{du} e^u = e^uu'[/tex]
You're going to have to apply the chain rule.
Does that help?
Does that help?
i think we are not looking at the same problem. my problem is an exponential within an exponential
d/dx e^(e^4x)
It's not the exact equation that you need to apply, but that's where you start. If I let [tex]u = e^{4x}[/tex], then I must first find the derivative of [tex]e^u[/tex].
I know [tex]\frac{d}{du} e^u = e^uu'[/tex].
So you know what "u" is, now you must find the derivative of "u" and plug it into the above equation.
oooooh.
i see. i guess just use substitution letting u = e^(4x)
by any chance, is the correct answer 4e^(4x) times e^(4x) = 4e^(8x)
Not quite, you want to think of "u" as separate from everything else and only plug it in at the end. If [tex]u = e^{4x}[/tex], what's the derivative, u' ?
thats exactly what i did. i made "u" separate.
and the derivative of u is 4e^(4x), to answer your question.
Right, so you'd have [tex]4e^{e^{4x}}e^{4x}[/tex]. I didn't see you type in the [tex]e^{e^{4x}}[/tex] part.
wow. totally confusing.
but i think the answer is what i stated earlier...
i get this by sticking to the basics and using the chain rule and substitution
I'm not trying to confuse you, haha, but I'd hope that you walk away from this understanding what's going on. Let's say I wanted to find the derivative of [tex]e^{e^x}[/tex]. I'd use the chain rule once again letting [tex]u = e^x[/tex]. So I'd have:
Find u':
[tex]u' = e^x * 1[/tex]
And plug u and u' into the first equation to get the derivative:
[tex]e^{e^x}*e^x*1[/tex]
Right?
check it. i was wrong. the answer should be
4e^(4x) times e^(e^(4x))
which is
u' times e^u
via the chainrule
Find u':
Right?
i follow you. you are right.
and how do you type in the equations like that? it looks clean...
Haha, you just use the "tex" tags. You can click on the equation itself to see how you would type it in. I think there's a tutorial somewhere here on the site.
