- 8,943
- 2,954
Some context for my question: If you have a smooth manifold \mathcal{M} you can define tangent vectors to parametrized paths in the following way: If \mathcal{P}(s) is a parametrized path, then
\frac{d}{ds} \mathcal{P}(s) = V
where V is the differential operator that acts on scalar fields \psi(\mathcal{P}) to give
V(\psi) = \frac{d}{ds} \psi(\mathcal{P}(s))
This actually defines a vector V(s) at each point along the path \mathcal{P}(s).
The way that I know of defining a derivative of V(s) involves a connection, or parallel transport:
\frac{d}{ds} V|_{s_0} = lim_{\delta s \rightarrow 0} \frac{V'(s_0 + \delta s) - V(s_0)}{\delta s}
where V'(s_0 + \delta s) is the result of parallel-transporting V(s_0 + \delta s) along the path \mathcal{P}(s) from s=s_0 + \delta s back to s_0.
My question is: can you define the derivative of a vector (or vector field) without using parallel transport?
