Derivative Transformation with Law of Cosines
The discussion focuses on applying the Law of Cosines to transform partial derivatives in a multivariable function context. The Law of Cosines is defined as a^2 = b^2 + c^2 - 2bc cos(A), where a, b, and c are triangle sides and A is the opposite angle. The participants clarify the need to differentiate between functions f(b, c, A) and F(b, c, a) to correctly apply the chain rule for derivatives. The transformation of derivatives is achieved by establishing relationships between the variables and using the chain rule effectively.
  • Understanding of the Law of Cosines
  • Knowledge of multivariable calculus and partial derivatives
  • Familiarity with the chain rule in calculus
  • Ability to manipulate and differentiate functions of multiple variables
  • Study the application of the chain rule in multivariable calculus
  • Learn about the geometric interpretation of the Law of Cosines
  • Explore examples of coordinate transformations in calculus
  • Investigate linear systems of equations in the context of partial derivatives
Students and professionals in mathematics, physics, and engineering who are dealing with multivariable functions and need to understand the transformation of derivatives using the Law of Cosines.
Solidmozza
Hi there,
The Law of Cosines can be stated as
a^2 = b^2 + c^2 - 2bccos(A)
where a,b, and c are the sides of a triangle, and A is the angle opposite the side a. I have a function, f(b,c,A), with an associated set of partial derivatives (\frac{∂f}{∂c})_{b,A} etc. What I want to do is to use a coordinate transformation to get the related derivatives (\frac{∂f}{∂c})_{b,a} etc. This looks like a multivariable partial derivative problem with a constraint. Using the chain rule, it seems to me that
(\frac{∂f}{∂c})_{b,A}=\frac{∂f}{∂c}+\frac{∂f}{∂a} \frac{∂a}{∂c}
(\frac{∂f}{∂c})_{b,a}=\frac{∂f}{∂c}+\frac{∂f}{∂A} \frac{∂A}{∂c}
where I think \frac{∂f}{∂c} is the same in both expressions. I can calculate the \frac{∂a}{∂c} and \frac{∂A}{∂c} parts using the Law of Cosines, but then I don't know what to do with \frac{∂f}{∂a} and \frac{∂f}{∂A}, i.e. if I use the transformation \frac{∂f}{∂a}=\frac{∂f}{∂A}\frac{∂A}{∂a} then it looks like (\frac{∂f}{∂c})_{b,A}=(\frac{∂f}{∂c})_{b,a} but numerical results and intuition tell me otherwise.
In essence, I don't know how to find the partial derivative (\frac{∂f}{∂c})_{b,a} given (\frac{∂f}{∂c})_{b,A} and that the variables are connected via the Law of Cosines.
Any assistance with this problem would be greatly appreciated :)
You are getting confused because you use the same symbol, f, to denote different functions. Do not do it. Let f be a function of (b, c, A). Then let F be a function of (b, c, a). Obviously, f(b, c, A) = F(b, c, a(b, c, A)), where a(b, c, A) is the cosine law. You need to obtain the derivatives of F, use the chain rule.
Hi Voko,
Thanks for the response, but I'm still a little stuck here. This is how I continued:
dF = (∂F/∂c)dc + (∂F/∂b)db + (∂F/∂a)da
Now (∂F/∂c)_{b,a} = (∂F/∂c) (is this not just (∂f/∂c)?)
And (∂F/∂c)_{b,A} = (∂F/∂c) + (∂F/∂A)(∂A/∂c)
But (∂A/∂c) = (c-bcosA)/a
Hence, (∂F/∂c)_{b,A} - (∂F/∂c)_{b,a} = (∂A/∂c)(c-bcosA)/a
However, this doesn't conform to what I have when I substitute in numerical values. I'm clearly not getting something here, could you give me a more forceful push?
Just to make sure we are on the same page. What you really have is ## \partial f/\partial b, \ \partial f/\partial c, \ \partial f/\partial A ##, correct? And you need to find ## \partial F/\partial b, \ \partial F/\partial c, \ \partial F/\partial a ##.
Then <br /> <br /> \frac {\partial f} {\partial b} = \frac {\partial} {\partial b} F (b, c, a(b, c, A)) = \frac {\partial F} {\partial b} + \frac {\partial F} {\partial a} \frac {\partial a } {\partial b}<br /> <br /> \\<br /> <br /> \frac {\partial f} {\partial c} = \frac {\partial} {\partial c} F (b, c, a(b, c, A)) = \frac {\partial F} {\partial c} + \frac {\partial F} {\partial a} \frac {\partial a } {\partial c}<br /> <br /> \\<br /> <br /> \frac {\partial f} {\partial A} = \frac {\partial} {\partial b} F (b, c, a(b, c, A)) = \frac {\partial F} {\partial a} \frac {\partial a } {\partial A}<br /> <br />
This is a linear system; solve for ## \partial F/\partial b, \ \partial F/\partial c, \ \partial F/\partial a ##.
Thanks a heap Voko, that did the trick! :)
