Derivatives, inflections, concavity [included pictures]
The discussion revolves around the concepts of derivatives, critical points, inflection points, and concavity in the context of polynomial and exponential functions. Participants are analyzing functions to determine maxima, minima, and points of inflection.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss taking derivatives to find critical points and using the quadratic formula to identify maxima and minima. There are questions about the correctness of their calculations and the implications of their results. Some participants express confusion about identifying inflection points and the conditions for concavity.
There is an ongoing exchange of ideas, with some participants providing guidance on how to approach the problems. Multiple interpretations of the results are being explored, particularly regarding the identification of maxima and minima, as well as the nature of inflection points.
Participants are working under the constraints of homework assignments, which may limit the information available for solving the problems. There is also a focus on ensuring that the definitions and conditions for critical points and concavity are understood correctly.
asdfsystema
7. First I took derivative and got f'(x)= 6x^2-72x+210. divided the whole thing by 6 and found the factors for x^2-12x+35. (x-7)(x-5) which will give me that the smaller critical number is x=5 and the bigger critical number is x=7.
8. First I set the equation to 0 and used the quadratic formula to get that x= -0.94721 and x= -0.05279. Afterwards, I plugged it back into the original equation and got that x=22.90486 which will be absolute maximum and x= 9.541833 which will be the absolute minimum. is this correct?
9. f(x)= x^2 * e^8x , first i took f'(x) and got f'(x)= e^8x * 2x + x^2 * 8e^8x
next , i took the second derivative and got f"(x)= [2x*8e^8x+2e^8x]+[8e^8x*2x + x^2*64e^8x]...
the next step, i have to set it to zero? Can anyone help me with that and tell me if i am doing this correctly please. Thanks a lot.
Yes, that is correct.
8. First I set the equation to 0 and used the quadratic formula to get that x= -0.94721 and x= -0.05279. Afterwards, I plugged it back into the original equation and got that x=22.90486 which will be absolute maximum and x= 9.541833 which will be the absolute minimum. is this correct?[/quote]
You solved 5x2- 10x + 9= 0? That does not have real roots. And you don't want to solve that anyway. You want to set the derivative equal to 0 and solve that. Of course, max and min might occur at the endpoints of the interval.
[quote9. f(x)= x^2 * e^8x , first i took f'(x) and got f'(x)= e^8x * 2x + x^2 * 8e^8x
the next step, i have to set it to zero? Can anyone help me with that and tell me if i am doing this correctly please. Thanks a lot.[/QUOTE]
Well, what is the definition of "inflection point"?
thank you for responding.
8. f(x)= 5x^2-10x+9
f'(x)= 10x-10
f'(x)=0 --> 10x-10=0 --> which will give me x=1 only. how will i know the max and min given that x=1 ? I plug it back in and am i missing another root?
9. the inflection point is when it changes from concave up to concave down or the opposite in any of the intervals
8. f(x)= 5x^2-10x+9
f'(x)= 10x-10
Maxima/minima occur where the derivative is zero or at endpoints of the interval on which the function is defined. The graph of this function is a parabola that opens upward. It's very likely that a maximum occurs at one of the two endpoints.
Not "it" -- the graph's concavity. This means that f''(x) is changing sign from positive to negative or from negative to positive. For this problem, find f''(x) and see where it is zero. If you find values of x for which f''(x) is zero, these values divide the real line into intervals on which f''(x) is negative or positive, which is the same as saying intervals on which the graph is concave down or concave up.
8.
f(x)=5x^2-10x+9
f'(x)= 10x-10
I set it to =0 and got x=1.
Then I made a table
which means that (0,9) is minimum and (6,129) is maximum?
9. f"(x)= [2x*8e^8x+2e^8x]+[8e^8x*2x + x^2*64e^8x]
I keep getting this as a second derivative and it's so long so I don't think it is right. Even if I set it to zero, how can i find out the many values of x that will make this 0? I think I know what to do next once I solve this problem. can you give me tips on a shortcut or a way how you would approach this ? thanks matt !
asdfsystema said:
8.
f(x)=5x^2-10x+9
f'(x)= 10x-10
Then I made a table
Ken, look at your table again. f(1) is smaller than 9, so the minimum is at (1, 9).
Your 2nd derivative looks OK, but here it is in more readable form:
f''(x) = 16xe^{8x} + 2e^{8x} + 16xe^{8x} + 64x^2e^{8x}
Factor e^(8x) out of all four terms, which leaves you with another factor that's a quadratic. Don't forget to combine like terms in the quadratic factor. e^(8x) > 0 for all real x, so the only possibility of f''(x) equaling zero comes from the quadratic being zero.
I've checked, and there are two inflection points, both negative.
8.
for number 8, did you mean the minimum is at (0,9) or (1,9)? Then does that mean the maximum will be at (6,129)?
9.
I really need to learn how to do that so it won't be so confusing next time.
Following your advice, I canceled out the e^8x and got the quadratic equation f"(x)= 64x^2+32x+2. Then I used the quadratic formula to find where x=0 and got two inflection points just like you said.
where x= -0.42677 and x= -0.07322
and finally, at (-inf,C) it will be concave up . at (C,D) it will be concave down and at (D,inf) it will be concave up ?
You should really consider being a professor. you are really good at making things clear and simple. Thanks a lot !
asdfsystema said:
8.
Sorry, I meant (1, 4) for the minimum.
asdfsystema said:
9.
The graph will be concave up on (-inf, C) and (D, inf) if f''(x) > 0 on those intervals. Similarly, the graph will be concave down on (C, D) if f''(x) < 0 on that interval. That's pretty easy to tell because your quadratic factors into K(x + .42677)(x + .07322). Assuming K is positive, this expression is positive for x less than -.42677 and for x greater than -.07322, and the expression is negative for values of x between those two numbers. (I used your numbers, which are approximations.)
Been there, done that. I taught math at a community college for 18 years. I guess I'm drawn to this forum because I enjoyed helping people with math, but I got tired of correcting homework and tests and such.
  • · Replies 23 ·
  • · Replies 19 ·
