What is the derivative of a constant in a function?
The derivative of a constant is always zero, which means it does not affect the overall derivative of a function. When dealing with expressions like x^2/3, it's crucial to clarify whether it represents (x^2)/3 or x^(2/3), as this changes the differentiation process. For (x^2)/3, the derivative is calculated as (1/3)(2x) = (2/3)x. In contrast, if interpreting x^(2/3), the derivative would be (2/3)x^(-1/3). Understanding the context and applying the correct differentiation rules is essential for accurate results.
hotrocks007
this is just a general question, one that keeps coming up everytime i take a test or quiz.
I understand that the derivative of a constant is zero, but I don't understand when you use that zero to multiply or divide in a problem, and when you just ignore that zero.
For example x^2/3
Would that be zero? or 2x?
Because I know in some problems you just ignore the constant when it is alone, but I'm not sure about when it is a variable.
Help is appreciated, I have a test tomorrow
Thanks
The derivative of a constant term is 0, in your case the term isn't constant. The "3" you're probably referring to is a factor which belongs to the term "x²/3".
Since the derivative is lineair, you can put the factor up front and get:
\left( {\frac{{x^2 }}<br /> {3}} \right)^\prime = \frac{1}<br /> {3}\left( {x^2 } \right)^\prime = \frac{{2x}}<br /> {3}
If y = a [a constant by itself], then dy/dx = 0.
If y = a f(x) [a constant times a function], then dy/dx = a (df/dx)
So if y = (1/3)x^2, then dy/dx = (1/3)(2x) = (2/3)x
For example x^2/3
Try applying the division rule to this. (of course, it's better if you remember the scalar multiplication rule, but since this is a sticky point for you, try doing it with the division rule and see if you're happy)
I don't think that is his problem, Hurkyl!
Because (f+ g)'= f'+ g', (f+ Constant)'= f'+ Constant'= f'+ 0= f' so you can "ignore" the constant. (Notice the quotes- you are not IGNORING it! You are THINKING about it, recognizing that its derivative is a constant and so "adding 0".
Because (fg)'= f'g+ fg', (Constant*g)'= (Constant)'g+ (Constant)g'= 0*g+ Constant*g'. The derivative of a constant times a function is the constant times the derivative of the function. I guess you could say you are "ignoring" the constant here but that's why I don't like that word! THINK about what you are doing!
Surely you know that every function involves some constants (even if they are 1). You can't just "ignore" them.
The two rules I mentioned above: (f+ Constant)'= f' and (Constant*f)'= Constant*f' are as close as you can come to "ignoring" the Constant!
I'm hoping he'll appreciate what's going on better if he does the division rule and sees the constant resurface at the end. :smile: In effect, I'm hoping he'll work out for himself exactly what you told him about the product rule.
hotrocks007 said:
For example x^2/3
i'm not seeing a constant there. a quick mental calculation gives \frac{d}{dx}f(x)=\frac{2}{3}x^{-\frac{1}{3}}
It depends on what the OP meant by "x^2/3": either (x^2)/3 or x^(2/3). (From the context I assumed he meant the former.)
that's why you use \LaTeX
And, of course, the strict interpretation x^2/3 is (x^2)/3.
And that's even true in Latex: x^2/3 = x^2/3. :smile:
then it's \frac{d}{dx}f(x)=\frac{2}{3}x
I was thinking that hotrocks007 meant x^(2/3) but was thinking "Aha- there's a constant, 2/3, in there and the derivative of a constant is 0! So the derivative of this is 0!" That was the reason for my remark that every function contains "constants"!
  • · Replies 20 ·
