Proving the Curl Identity for a Simple Curl Equation
The discussion centers on proving the curl identity for the equation involving the curl of a product of a scalar and a gradient. The key point is that the final term in the expansion, which is a triple sum, should equate to the zero vector. Participants highlight the properties of the Levi-Civita symbol and the symmetry of mixed partial derivatives to demonstrate that the components cancel out. The conclusion emphasizes that if a vector is derived from a gradient, its curl must be zero, reinforcing the identity. Overall, the mathematical properties discussed effectively validate the original curl equation.
Hiero
Simplify ##\nabla \times ( a\nabla b)##
##\nabla\times \vec V = \epsilon_{ijk}\frac{\partial V_k}{\partial x_j}\hat e_i##
##\nabla s = \frac{\partial s}{\partial x_i}\hat e_i##
Attempt:
$$\nabla \times ( a\nabla b) = \epsilon_{ijk}\frac{\partial}{\partial x_j}(a\frac{\partial b}{\partial x_k})\hat e_i$$ $$ = \epsilon_{ijk}\big(\frac{\partial a}{\partial x_j}\frac{\partial b}{\partial x_k}+a\frac{\partial b}{\partial x_j\partial x_k}\big)\hat e_i$$ $$= \nabla a \times \nabla b + \text{(final term)}$$
That “final term” (a triple sum) should be the zero vector, but I cannot see how. Maybe I messed up elsewhere.
Thanks.
Well, \epsilon_{ijk} = -\epsilon_{ikj} but \partial_j\partial_kb = \partial_k\partial_jb so <br /> \epsilon_{ijk}\partial_j\partial_kb = -\epsilon_{ikj}\partial_k\partial_jb. But j and k are dummy indices, so we can relabel them on the right hand side ...
Likes Hiero
That’s a very nice way to show it is zero. The last step (after relabeling) is that ##[x=-x] \implies [x=0]##
I have to admit it seems magical to use this property ignoring the invisible nested summation.
Basically though, each component cancels out in pairs by virtue of the two properties you mentioned:
Alternatively, \nabla \times (a\mathbf{v}) = (\nabla a) \times \mathbf{v} + a \nabla \times \mathbf{v} and if \mathbf{v} is a gradient then its curl is zero (which follows from the observation in my earlier post).
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 23 ·
  • · Replies 18 ·
