Deriving equations from fourier series representations
The discussion focuses on the challenge of deriving an intuitive representation of a function from its Fourier series coefficients. While the Fourier series provides a mathematical expression for the function, it often lacks clarity in visualizing the actual shape, as demonstrated with the square wave example. Participants note that without prior knowledge of the function's characteristics, recognizing its form from the series can be difficult. The consensus suggests that computational tools for plotting may be the most effective way to gain insight into the function's behavior. Ultimately, developing intuition about functions typically requires experience with various examples over time.
seanbow
Say you have the coefficients a_k of a Fourier series representation of some function x(t). You can easily then give x(t) as
$$x(t) = \sum_{k = -\infty}^{\infty} a_k e^{i k \omega_0 t}$$
But this doesn't do much good in telling you what the actual function looks like. For example, if we have
$$a_k = \frac{ \sin ( k \pi / 2)} {k \pi}$$
we can write x(t) as
x(t) = \sum_{k \neq 0} \frac{ \sin (k \pi / 2)} {k \pi} e^{i k \omega_0 t}
but you would have a hard time telling that this is a square wave with a duty cycle of 50% unless you've previously derived the series coefficients for that exact function.
Basically, my question is: is there a way to derive a more intuitive representation of a function given its Fourier series representation?
Mathematics news on Phys.org
Not that I'm aware of, except by using computer power to plot the function. Additionally intuition is a rather personal property. It develops usually over time when more and more functions add to your experience.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
