A Could the Gravitational Constant G have a quantum origin?
Lasand
TL;DR Summary
Does the Gravitational Constant have a quantum basis.
Could the numerical value of the Gravitational Constant G have a quantum basis?
G=(2pi x h-bar) + h/137
Lasand said:
TL;DR Summary: Does the Gravitational Constant have a quantum basis.
No. This equation is a numerical coincidence in SI-units. However, the SI-units on the right differ from those on the left. The equation collapses if you choose other units, e.g., yards instead of meters and pounds instead of kilograms.
Likes arivero, ohwilleke, pines-demon and 3 others
According to my reading of the old papers, at the start of the 1990s, naive use of string theory was outputting a value of the gravitational constant (in string units) that was wrong by one or two orders of magnitude - which might sound like a lot, but given that these numbers can apriori range across many orders of magnitude, is somewhat promising. Ways to obtain a more accurate value were discussed (e.g. see page 18 of Dienes 1996). Then, in Witten 1996, Witten identified situations in string theory where gravitational and gauge couplings are related, and situations where they aren't. (He was able to do this, as a side effect of the recent understanding of strongly coupled strings, that included the development of M-theory.)
Speaking of string theorists, Lubos Motl posted about this subject on Quora last month.
Likes ohwilleke and fresh_42
Emergent gravity seeks to explain gravity as non-fundamental, and take an approach very different than the papers Mitchell Porter references.
It wouldn't produce anything resembling the formula in the OP.
It also doesn't really derive Newton's constant, so much as it does shift it to Planck's length (which is a function of several physical constants chosen to combine in the dimension of length including Newton's constant and Planck's constant), however.
By analogy, in the Standard Model, fundamental charged fermion masses are no longer fundamental, but they are just replaced with Higgs field Yukawa's which are experimentally determined and can't be derived.
If it were possible to derive G out of h and c, should we start discussing with one is the derived and which ones are the two fundamentals?
As we stand today, with a relationship between four constants,
we consider that Planck Length is the derived one. But it is fun to consider eg that we can do path integral in terms of Planck Length, Newton Constant and Lightspeed, and forget about hbar.
There are also several ways to express Newton's constant in dimensionless form, like the other three coupling constants.
This is an alert about a claim regarding the standard model, that got a burst of attention in the past two weeks. The original paper came out last year: "The electroweak η_W meson" by Gia Dvali, Archil Kobakhidze, Otari Sakhelashvili (2024) The recent follow-up and other responses are "η_W-meson from topological properties of the electroweak vacuum" by Dvali et al "Hiding in Plain Sight, the electroweak η_W" by Giacomo Cacciapaglia, Francesco Sannino, Jessica Turner "Astrophysical...
In LQG and LQC there are solutions called "black to white transition". I'll add some references: (Rovelli)https://arxiv.org/abs/1905.07251 (Rovelli)https://arxiv.org/abs/2302.03872 (Rovelli)https://arxiv.org/abs/1803.06330 (Rovelli)https://arxiv.org/pdf/1802.04264 (Rovelli)https://arxiv.org/abs/2108.12823 https://arxiv.org/abs/2304.02691 https://arxiv.org/abs/2110.07589 https://arxiv.org/abs/2009.01788 https://arxiv.org/abs/1911.12646 https://arxiv.org/abs/1801.03027...
Hello everyone, I am seeking to better understand the conceptual foundations and potential consequences of "Two-Time Physics" (2T-physics), as developed by Itzhak Bars and others. My interest was sparked by a recent paper that attempts to explain anomalous results in particle physics (apparent superluminal propagation of virtual photons) within the framework of 2T-physics: Paper: https://arxiv.org/abs/2408.02696 Key quote from the abstract: *"...the problem... can be solved naturally...
