Deriving the solution to the Abel equation
  • Context: Graduate
  • Thread starter Thread starter saltydog
5 replies · 7K views
Homework Helper
I wish to study the Abel equation and think it's solution involves several aspects of Calculus that others here may find interesting. I'll post the derivation of the solution in steps; that helps me learn it and I hope will provide incentive to others to comment about the process. I'm not really good with integral equations and welcome any comments; my understanding is quite lacking. I just like them and see the potential of them (and IDEs) being used in artificial intelligence.
Here's the equation:
[tex]f(x)=\int_0^x{\frac{\phi(y)}{\sqrt{x-y}}}[/tex]
With [itex]f(x)[/itex] given and [itex]\phi(x)[/itex] to be determined.
The first step in solving the equation is to define an integral operator, that is, an operator which takes a function and processes it with an integral. For this problem, Abel used the following integral operator:
[tex]I[f(x)]=\int_0^\xi{\frac{f(x)dx}{\sqrt{\xi-x}}}[/tex]
Thus, applying this operator to both sides of the equation yields:
[tex]\int_0^\xi{\frac{f(x)dx}{\sqrt{\xi-x}}}=\int_0^\xi{\frac{dx}{\sqrt{\xi-x}}}\int_0^x{\frac{\phi(y)}{\sqrt{x-y}}}dy[/tex]
The order of integration on the RHS needs to be changed next.
Switching the order of integration
It's easy for me to switch the order of integration when I consider the integral in the following form:
[tex]\int_0^\xi\int_0^x f(x,y;\xi)dydx[/tex]
The area of integration is then the triangular region under the graph [itex]y=x[/itex] in the range [itex][0,\xi][/itex]. In this case, the integral becomes:
[tex]\int_0^\xi\int_y^\xi f(x,y;\xi)dxdy[/tex]
And thus:
[tex]\int_0^\xi{\frac{dx}{\sqrt{\xi-x}}}\int_0^x{\frac{\phi(y)}{\sqrt{x-y}}}dy=\int_0^\xi\int_y^\xi \frac{1}{\sqrt{\xi-x}}\frac{\phi(y)}{\sqrt{x-y}}dxdy[/tex]
The transformed integral equation becomes:
[tex]\int_0^\xi\frac{f(x)}{\sqrt{\xi-x}}dx=\int_0^\xi\phi(y)\int_y^\xi\frac{1}{\sqrt{\xi-x}\sqrt{x-y}}dxdy[/tex]
The next step is to find a suitable change of variable that will facilitate evaluating the first iterated integral.
Using the change of variable [itex]x=y+(\xi-y)u[/itex], the integral on the RHS becomes:
[tex]\int_0^\xi \phi(y)\int_0^1\frac{(\xi-y)du}{\sqrt{(\xi-y-\xi u+yu)(\xi u-yu)}}}dy[/tex]
Simplifying, we get:
[tex]\int_0^\xi \phi(y)\int_0^1\frac{du}{\sqrt{u(1-u)}}dy[/tex]
Well, how convenient. This seems to be the critical part of the solution process. In this case, everything cancels. I'd like to come back to this part with a kernel that does not cancel so nicely but for now, I stick with the easy problem.
The equation is now:
[tex]\int_0^\xi \frac{f(x) dx}{\sqrt{\xi-x}}=\int_0^\xi \phi(y)\int_0^1\frac{du}{\sqrt{u(1-u)}}dy[/tex]
The first iterated integral is easily solved.
Incorrect usage in first post
I now realize it's incorrect to call the first step in the solution process an "integral transform" as a transform would involve a "dummy" variable for the integral. Rather, I'm just multiplying both sides of the original integral equation by [itex]\frac{dx}{\sqrt{\xi-x}}[/itex] and then integrating from 0 to [itex]\xi[/itex].
Continuing:
Completing the square in the radical, the antiderivative is in the form of ArcSin. The integral is equal to [itex]\pi[/itex]
So that:
[tex]\int_0^\xi \frac{f(x)dx}{\sqrt{\xi-x}}=\pi \int_0^\xi \phi(y)dy[/tex]
In order to isolate [itex]\phi[/itex], we differentiate both sides of the equation with respect to [itex]\xi[/itex] so that:
[tex]\phi(\xi)=\frac{1}{\pi}\frac{d}{d\xi}\int_0^\xi\frac{f(x)dx}{\sqrt{\xi-x}}[/tex]
The interesting point here is that Leibnitz's rule cannot be used here as the integrand is discontinuous at [itex]x=\xi[/itex]. However, the integral can be simplified by parts leaving:
[tex]\phi(\xi)=\frac{1}{\pi}\frac{d}{d\xi}\{2f(0)\sqrt{x}+2\int_0^\xi \sqrt{\xi-x}f^{'}(x)dx\}[/tex]
Or using Leibnitz rule:
[tex]\phi(\xi)=\frac{f(0)}{\pi \sqrt{\xi}}+\frac{1}{\pi}\int_0^\xi \frac{f^{'}(x)}{\sqrt{\xi-x}}dx[/tex]
Wow, that's beautiful. Now it's time to begin experimenting with various functions [itex]f(x)[/itex] in Mathematica in an effort to better understand the behavior of this integral equation from the perspective of "I don't care about the application, only the math".
For a numerical treatment (using FORTTRAN) visit wwwdotgeocitiessdotcomslashserienumerica
