Deriving the vapor pressure latent heat dependence
18 replies · 2K views
il27
There is a picture attached showing the entire problem.
Equation 2.78 is the Clausius Clapeyron equation.
Clausius Clayperon equation.
L = L'T (since there is a linear dependence on temperature)
$$ \frac{de_s}{dT} = \frac{L}{T\alpha} $$
$$ pV = RT $$ $$ V= RT/p $$
$$ \frac{dp_s}{dT} = \frac{L}{(RT^2)/p} $$
i am not sure how to continue with this though.
Let ##L_0## be the latent heat of vaporization at 0 C and ##L_{100}## be the latent heat of vaporization at 100 C. In terms of the absolute temperature T, what is the latent heat of vaporization at absolute temperature T?
In terms of absolute temperature, the latent heat of vaporaization would be:
$$ L = 19T + 334 $$ 334 being the latent heat of water at 0 deg C. is that right?
I want it algebraically in terms of ##L_0## and ##L_{100}##. And I asked for it in terms of the absolute temperature T, not the centigrade temperature.
Would it be: $$ L = L_{100}*T + L_0 $$ ?
Do you not know how to determine the equation for the straight line L vs T that passes through the points (273,##L_0##) and (373, ##L_{100}##)?
oh sorry!
that was dumb. yes of course. the equation i get for L is $$ L = (\frac{L_{100}-L_0}{100})T $$ no y-intercept.
what would be the next step?
il27 said:
oh sorry!
Incorrect. Try again.
sorry! i think i forgot the y-intercept.
$$ L =
il27 said:
oh sorry!
sorry! the slope is fine right? i think i forgot the y-intercept:
$$ L = (\frac{L_{100}-L_0}{100})T + 3.73L_0 - 2.73L_{100} $$
$$L = (\frac{L_{100}-L_0}{100})T + 3.73L_0 - 2.73L_{100} $$
OK. So now you have $$\frac{d\ln{p_s}}{dT}=\frac{L}{RT^2}$$
Now all you need to do is substitute for L, and integrate from T1 to T2.
great, thank you! I think when I did the $$ RT^2 $$, that was wrong. i will just integrate:
$$ \frac{dp_s}{dT} = \frac{de_s}{dT} = \frac{L}{T\alpha_v} $$ for the pressure. i will plug in for L. would that be okay?
The version with ##RT^2## was correct, and the equation I wrote was correct.
oh okay, i will use that one then! thank you.
just wondering, what is the $$ \alpha_v $$ that is a constant right?
No. It’s RT/ps
Chestermiller said:
Yes, it’s the molar volume of the vapor.
great thank you! and m
and i just wanted to check but my euqation for L is correct?:
also, would I be integrating from p0 to p, p0 being 101325 pa, and T1 to T2?
because if i want to find the vaporation pressure using the new equation with the temperature of 20 deg. C, what would be my T1 and T2?
like if i wanted to:
Use the expression derived in part (a) to recalculate the saturation vapor pressure at 20 °C.
