Deriving The Work-Energy Theorem
The discussion revolves around deriving the work-energy theorem without manipulating differentials. Participants are exploring the relationships between force, mass, acceleration, and work, as well as the definitions and interpretations of differentials in calculus.
  • Some participants attempt to derive the theorem by expressing force in terms of mass and acceleration, while questioning the validity of treating differentials as fractions. Others suggest considering the definitions of work and motion to guide the derivation.
Participants are actively engaging with each other's ideas, questioning assumptions about differentials, and exploring various interpretations of the work-energy theorem. Some guidance has been offered regarding the treatment of differentials and the use of the chain rule, but no consensus has been reached.
There is a noted concern about the instructional nature of the problem and the participants' varying levels of comfort with calculus concepts, particularly regarding differentials and their definitions.
Superman1271
Trying to derive the work-energy theorem, without manipulating differentials.
a=[itex]\frac{dv}{dt}[/itex] v=[itex]\frac{dx}{dt}[/itex]
W=[itex]\int[/itex] F dx =ΔKE=[itex]\frac{1}{2}[/itex]mvf[itex]^{2}[/itex]-mvi[itex]^{2}[/itex]
F=ma
[itex]\int[/itex] F dx=m[itex]\int[/itex]a dx
=m[itex]\int[/itex][itex]\frac{dv}{dt}[/itex]dx <-- I cannot continue, unless I start using the differentials as fractions. Can you move forward without thinking of them as fractions? Or if you choose to use them as fractions could you justify the act?
F=ma
dv is just the arbitrarily small change in velocity occurring in the arbitrarily small time interval dt. So long as dx is the arbitrarily small change in displacement in that same time interval, and you can effectively treat them as fractions. So, (dv/dt)dx = (dx/dt)dv
Does that help?
AM
Keep in mind that velocity and force are vectors and energy is a scalar. Write down Newton's equation of motion and think about, how to derive a scalar equation and then integrate. Just another hint: Think about, how work is defined in terms of the force and the trajectory of the particle as a function of time!
I always use F=dp/dt in vector form. But then I manipulate the differentials - this is permitted by the chain rule.
So perhaps you should go to the definitions, and work it out from that perspective. Clearly the problem is intended to be instructional, and working with definitions is always that.
Does that help?
AM
Yes, this is how I was taught to derive this theorem. I still hope for something more, since I have not looked at non-standard analysis and have not defined differentials in a rigorous way.
My equations are 1 dimensional, force is acting in the positive or negative x-axis. Isn't that a scalar equation from Newtons's equation of motion? Work is defined as the sum of all contributions of force in the direction of motion multiplied by their respective distances? I'm sorry I don't see how these hints help.
That is interesting. How does the chain rule allow you to manipulate differentials as fractions.
UltrafastPED (unfortunately) posted already the answer in his link :-(.
## dv = \frac {dv} {dt} dt ## holds pretty much by definition, so whether you interpret that as if the derivative were a ratio of differentials is a matter of style more than anything else.
I do not think this is a matter style. The derivative is based on a limit, and is given the notation[itex]\frac{dy}{dx}[/itex]. For you to treat them as if they were fractions is quite strange to me.
How does that hold by definition? How can you isolate dv like that? It seems intuitively to be correct, but still not enough to be considered justified.
In fact, historically it was exactly how they were treated and this is why the notation is in terns of fractions.
Give us your definitions of the differential and the derivative and we can discuss that.
One definition of the differential is that if ## f(x) ## is given, and if there exist functions ## df(x, z), \ R(x, z) ## such that ##df(x, z)## is linear in the z-argument and ## f(x + z) - f(x) = df(x, z) + R(x, z) ## and moreover ## \lim_{z \to 0} R(x, z)/z = 0 ##, then ## df ## is the differential of the function.
It is then trivial to show that if the derivative ## f'(x) ## exists, then ## df(x, z) = f'(x)z ##. Now if we use ## dx ## in the stead of ## z ##, and the symbol ## \frac {df} {dx} ## for ## f'(x) ##, we obtain ## df = \frac {df} {dx} dx ##.
There is no need to split up the derivative (in Leibniz notation) as though it were a fraction. For your integrand, you have, by the chain rule:[tex]\frac{dv}{dt} = \frac{dv}{dx}\frac{dx}{dt} = v\frac{dv}{dx}[/tex] Where the last equality follows because dx/dt = v by definition. Now, if you examine the rightmost expression, you can see that it looks like something that has been differentiated w.r.t. x using the chain rule. If you "reverse" this application of the chain rule, you can turn the expression into something from which the kinetic energy will follow.
Thanks for this, I can sort of follow it. R(x,z) is some sort of remainder function?
I don't have a definition of the differential, which is my problem.
The definition of the derivative which I have been using is
lim h->0 [itex]\frac{f(x+h)-f(x)}{h}[/itex]
Could you recommend some problems to look at? Or some sources to read to get a better grasp of this idea. I have been hung up about this for a while now.
=m[itex]\int[/itex][itex]\frac{dv}{dx}[/itex][itex]\frac{dx}{dt}[/itex]dx
=m[itex]\int[/itex]v[itex]\frac{dv}{dx}[/itex]dx
[itex]\frac{d(1/2v^2)}{dx}[/itex] =1/2*(2v)*[itex]\frac{dv}{dx}[/itex]=v*[itex]\frac{dv}<br /> {dx}[/itex]
∴m[itex]\int[/itex]v[itex]\frac{dv}{dx}[/itex]dx=m[itex]\int[/itex][itex]\frac{d(1/2v^2)}{dx}[/itex]dx
=[itex]\frac{1}{2}[/itex]mv2!
Thank you everyone for your help :).
I would recommend Courant's Differential and Integral Calculus. It is freely available online: http://archive.org/details/DifferentialIntegralCalculusVolI
Section II.3.9 (p. 109) explains the connection between the derivative and the differential; II.3.10 discusses why in physics and natural science it is perfectly valid to treat the derivative as a quotient.
More modern books tend to omit the entire discussion of differentials in single-variable calculus (which they can get away with). When it comes to multi-variate calculus, they have to define the differential and discuss its properties; even then, however, they may not use the name "differential" - but you should be able to recognize one via the definition I gave earlier. The whole idea of the differential, in single and multi-variate calculus, is that it is a linear approximation to a function at a point; and the derivative is the slope of the approximation. It is because of the linearity that we can use the quotient trickery.
Glad to be of help and glad you worked it out. By the way, I wasn't trying to negate what others in the thread were saying about how you will get the right answer (in most situations) by using "differentials" or treating dy/dx as a fraction. That is true. In fact, you can think of my post as answering your question in post #8 (why does the chain rule allow you to treat derivatives as fractions) by showing that, at the very least, the two methods are mutually consistent.
I will check it out, thanks!
