Design of a simple fence post remover
  • Thread starter Thread starter qasimdada
    Design
The discussion focuses on designing a simple fence post remover for a farmer needing to extract posts buried 18 inches deep, requiring a maximum force of 175 lbs. The proposed solution involves using two wooden planks as supports and a strong rope connected to a truck to apply the necessary force. Key concerns include the distribution of force in the rope and the calculation of moments to ensure the posts are removed without breaking. The design neglects friction, simplifying the mechanics involved.
  • Understanding of basic mechanics, specifically force distribution
  • Knowledge of moments and leverage principles
  • Familiarity with materials science, particularly the strength of wood and rope
  • Basic engineering design principles for simple machines
  • Research the principles of force distribution in ropes and pulleys
  • Study the calculation of moments in static systems
  • Explore different types of wood and their load-bearing capacities
  • Learn about mechanical advantage in lever systems
This discussion is beneficial for mechanical engineers, agricultural equipment designers, and anyone involved in practical engineering solutions for farm operations.
qasimdada
I have been given an assignment of designing a simple fence post remover. Here is what the question says.
“A farmer wishes to remove several fence posts. Each post is buried 18 inches in the ground and will require a maximum force of 175lb to remove it. He can use his truck to develop the force but he needs to devise a method for their removal without breaking the posts. Design a method considering that the only material available is a strong rope and various pieces of wood of different size and length.”
I am allowed to neglect the friction.
I have planned to use two planks of wood as a support. The planks will be place on equal distances from the post and that distance will be of their height. The rope will be tied to one plank and will pass through the fence post (using a hole or hook in the post) and above the second plank and tied to the truck. But I am confused about 2 issues.
1. Distribution of Force in the rope.
2. Moments
Please help A.S.A.P.
Attached is the idea sketch
