DiracBlue
- 1
In this lab, we are supposed to design and build a multi-page schematic for the operation of an 4-bit arithmetic logic unit (ALU) capable of performing addition (ADD), negation (NOT), and bitwise AND (using Mutlimedia Logic). You will then build a memory with four lines capable of storing four bits per line.
I don't even understand how to start. I have a general idea of which gates to make/the circuitry for the addition, but as for the subtraction, 2-bit AND and even the layout of the ALU/memory I am completely lost. Any help would be amazing.
I know we need to use:
# Have two 4-bit inputs using two keypads
# Have one 4-bit output using a 7-segment displays
# Be capable of displaying both inputs using a 7-segment display for each input
# Capture the input in D-flip-flops (labeled "SR1" and "SR2" for source register)
# Have a clock button (labeled "CLK")
# Have a global reset to reset all registers and displays (labeled "Reset")
# Allow the user to input LC-3 opcodes using switches (see textbook), and store the opcode in an instruction register (labeled "IR")
# Display the operation in progress with LEDs or other output device
# Be capable of performing a bitwise AND of the two operands
# Be capable of performing a bitwise NOT of the first operand
# Be capable of performing an ADD of the two operands using a ripple-carry full adder
# Capture the result of the operation with D-flip-flops (labeled "DR")
# Display the result of the operation on a 7-segment display
# Display with an LED if the result of an ADD had a carry-out
# Display with an LED if the output of the ALU is zero (labeled "Z")
# Display with an LED if the output of the ALU is positive (labeled "P")
# Display with an LED if the output of the ALU is negative (labeled "N")
I have the statement for the addition: f3=A, f2= A'(and)B + A(and)B', f1= B(and)C' + B'(and)C and f0= A'C'D + A'CD' + ABD' + AB'D
