Designing an Amplifier Circuit with Single Source
The discussion revolves around designing an amplifier circuit that operates with a single power source, specifically addressing the challenges faced when connecting to a speaker circuit using NPN and PNP transistors. Participants explore alternative circuit designs and biasing methods to achieve the desired output signal.
  • Homework-related
  • One participant describes their project involving an amplifier circuit and expresses the need for a solution to connect to a speaker using a single power source.
  • Another participant interprets the request as needing to convert the circuit to function with only a positive supply and ground, suggesting that biasing the output to half of the positive supply could be a solution.
  • A different participant mentions an attempt to connect the speaker between the two emitters of the transistors but reports that there was no voltage across the speaker terminals.
The discussion remains unresolved, with multiple competing views on how to modify the amplifier circuit to work with a single power source. Participants have not reached a consensus on the best approach or solution.
There are limitations in the clarity of the initial posts, and some assumptions about circuit design and biasing methods are not fully explored or defined.
Em Jay
hi ..
i am doing a poject for my college and .. i design the amplifier
but when i connect to the speaker circuit ...of cource u konw it
npn and pnp transistor ..
the proplem is that i have to get to source on +ve and _ve
is there any circuit that i can have the right signal
with one cource
i need a help over here so...
i waiting ..
this the circuit i need an alternative of the last part
http://www.shbka.net/uploads/104012010156102734.jpg
my regards ..
Your message is not very clear. Some words seem to be missing. Could you please try posting it again.
Try as hard as you can to write clearly and please check your spelling.
Em Jay said:
hi ..
with one cource
i waiting ..
my regards ..
I think maybe you're asking how to convert this circuit to work with just a positive +Ve supply and ground, with no symmetrical -Ve supply?
If so, just bias up the amp's output to half of +Ve. There are several ways to do this. Can you suggest at least two of the ways?
yeah .. some one told me to put the speaker between the two Emitter ..but when i did that there are no volt a cross the speaker terminal ..
but can put the circuit here ...
  • · Replies 20 ·
  • · Replies 23 ·
  • · Replies 27 ·
  • · Replies 22 ·
