Designing an Unstayed Mast for a Sail: Calculations and Lamination Schedule
The discussion revolves around the design and calculations for an unstayed mast intended for a sail, focusing on the lamination schedule and material properties. Participants explore the implications of various design choices, including the selection of tensile strength, the positioning of sail force, and the overall safety of the design. The context includes theoretical and practical considerations relevant to composite materials in engineering applications.
  • Homework-related
  • One participant proposes a yielding tensile strength of 160 MPa for the composite material, arguing that it accounts for safety margins and material properties.
  • Another participant mentions that the AWS (Average Wind Speed) should be calculated as 1.25 times the design wind speed, suggesting a potential adjustment in calculations.
  • The original poster questions the safety of their design choices, including the placement of sail force at the top of the mast and the addition of layers to the lamination schedule for enhanced strength.
  • Participants express uncertainty about the appropriateness of the chosen tensile strength and whether the design choices are indeed safe.
  • There are requests for feedback on potential flaws in the calculations or logic presented in the initial post.
Participants do not reach a consensus on the safety and sensibility of the chosen tensile strength or the overall design choices. Multiple viewpoints and uncertainties remain regarding the calculations and assumptions made.
Participants note that the calculations depend on various assumptions, including the yielding tensile strength and the interpretation of design standards. There is also a lack of clarity on how the adjustments to AWS impact the overall design.
magwas
There is an unstayed mast which is 3m long, supported at the bottom and at 0.5m from the bottom.
Sail area is 10 m^2, design wind speed is 50 km/h.
It is made from glass epoxy composite.
The base fiber is 300 g/m^2 glass textile. E-glass, 2/2 twill.
The inner diameter is 40mm.
Develop the lamination schedule for the mast.
Force of wind on the sail:
[tex]F_{0}=\frac{1}{2} A C_{s} \rho AWS^{2}[/tex]
Euler-Bernoulli beam equation:
[tex]Rp_{02} = \frac{M y}{Ix}[/tex]
second moment of inertia in a circular beam:
[tex]Ix = \frac{1}{4} \pi \left(ro^{4} - ri^{4}\right)[/tex]
My first problem is to come up with a sensible yielding tensile strength for the material.
I have the following data:
1.) Flexural "Maximum resistance" of a composit made of E Glass, 2/2 Twill, 300 g/m² is 662 MPa
2..) ABS standard gives 124 MPa for "Tensile Strength" for "basic laminate", which is defined as:
The basic laminate consists of an unsaturated general-purpose polyester resin and alternate plies of
E-glass, fiberglass mat and fiberglass-woven roving fabricated by the contact or hand lay-up process.
The minimum glass content of this laminate is 35% by weight.
3. minimum ultimate tensile strength in fiber direction of a laminate made by 300 g/m^2 plain weave is 70.4 ksi = 485 Mpa
Somewhat arbitrarily I have choosen 160 MPa as yielding tensile strength. (I call it Rp02, because this number is actually yield strength of T-66 Al).
Line of thought:
- as the composite is stiff, yield strength must be close to ultimate strength
- both composites close to the choosen one have far more than 400Mpa as ultimate tensile strength. Choosing a value less than half of that should account for both difference in yielding and ultimate strength and safety factor. This is also not much more than "basic laminate" which is obviously weaker than our material due to the reinforcement material used.
Is the choosen value a safe one?
known values:
[tex]$<br /> A = 10 m^{2} \\<br /> AWS = 17.3611111111111 \frac{m}{s} \\<br /> C_{s} = 1.1 \\<br /> Rp_{02} = 160000000.0 \frac{N}{m^{2}} \\<br /> l_{1} = 2.5 m \\<br /> l_{2} = 0.5 m \\<br /> \rho = 1.2 \frac{kg}{m^{3}} \\<br /> ri = 0.02 m \\[/tex]
Though F0 acts in the center of the sail, I have choosen to account for it at the top of the mast for additional safety margin and ease of calculation.
[tex]F_{1}=- \frac{F_{0} l_{1} + F_{0} l_{2}}{l_{2}}[/tex]
[tex]F_{2}=- F_{0} - F_{1}[/tex]
shear:
[tex]$\begin{cases} 0 & \text{for}\: x < 0 \\F_{0} & \text{for}\: \operatorname{And}\left(0 \leq x,x < l_{1}\right) \\F_{0} + F_{1} & \text{for}\: \operatorname{And}\left(l_{1} \leq x,x < l_{1} + l_{2},0 \leq x\right) <br /> \\F_{0} + F_{1} + F_{2} & \text{for}\: \operatorname{And}\left(l_{1} + l_{2} \leq x,l_{1} \leq x,0 \leq x\right) \end{cases}$[/tex]
moment:
[tex]\begin{cases} 0 & \text{for}\: x < 0 \\F_{0} x & \text{for}\: \operatorname{And}\left(0 \leq x,x < l_{1}\right) \\F_{0} l_{1} + x \left(F_{0} + F_{1}\right) - l_{1} \left(F_{0} + F_{1}\right) & \text{for}\: \operatorname{And}\left(l_{1} \leq x,x < l_{1} + l_{2},0 \leq x\right) <br /> \\ F_{0} l_{1} + x \left(F_{0} + F_{1} + F_{2}\right) + \left(F_{0} <br /> + F_{1}\right) \left(l_{1} + l_{2}\right) - l_{1} \left(F_{0} + F_{1}\right) - \left(l_{1} + l_{2}\right) \left(F_{0} + F_{1} + F_{2}\right) & \text{for}\: \operatorname{And}\left(l_{1} + l_{2} \leq x,l_{1} \leq x,0 \leq x\right)\end{cases}[/tex]
substituing together:
[tex]Rp_{02} = 4 \frac{M ro}{\pi \left(ro^{4} - ri^{4}\right)}[/tex]
to get the wall thickness, substitue ro = ri + dr:
[tex]Rp_{02} = 4 \frac{M \left(dr + ri\right)}{\pi \left(\left(dr + ri\right)^{4} - ri^{4}\right)}$[/tex]
Substituing moment:
[tex]Rp_{02} = 4 \frac{\left(dr + ri\right) \begin{cases} 0 & \text{for}\: x < 0 \\F_{0} x & \text{for}\: \operatorname{And}\left(0 \leq x,x < l_{1}\right) \\F_{0} l_{1} + x \left(F_{0} + F_{1}\right) - l_{1} \left(F_{0} + F_{1}\right) & \text{for}\: \operatorname{And}\left(l_{1} \leq x,x < l_{1} + l_{2},0 \leq x\right)<br /> \\F_{0} l_{1} + x \left(F_{0} + F_{1} + F_{2}\right) + \left(F_{0} + F_{1}\right) \left(l_{1} + l_{2}\right) - l_{1} \left(F_{0} + F_{1}\right) - \left(l_{1} + l_{2}\right) <br /> \left(F_{0} + F_{1} + F_{2}\right) & \text{for}\: \operatorname{And}\left(l_{1} + l_{2} \leq x,l_{1} \leq x,0 \leq x\right) \end{cases}}{\pi \left(\left(dr + ri\right)^{4} - ri^{4}\right)}[/tex]
Solving it for dr and choosing the positive real solution for each 0.1m gives:
0.0 None
0.1 0.000965014828703786
0.2 0.00188223960651223
0.3 0.00275403303707307
0.4 0.00358340696727762
0.5 0.00437357386074760
0.6 0.00512769600546226
0.7 0.00584875779631873
0.8 0.00653950969566895
0.9 0.00720245225745922
1.0 0.00783984146648781
1.1 0.00845370456306660
1.2 0.00904586024950311
1.3 0.00961793994178479
1.4 0.0101714083263240
1.5 0.0107075823892620
1.6 0.0112276485919169
1.7 0.0117326781397463
1.8 0.0122236404327593
1.9 0.0127014148504254
2.0 0.0131668010473501
2.1 0.0136205279367525
2.2 0.0140632615282017
2.3 0.0144956117704763
2.4 0.0149181385332672
2.5 0.0153313568446162
2.6 0.0131668010473501
2.7 0.0107075823892620
2.8 0.00783984146648781
2.9 0.00437357386074760
Layer thickness is 0.25mm for each 100 g/m^2 according to ABS standard, so dividing the above numbers with 0.00075 and rounding up gives the number of layers:
0.1 2
0.2 3
0.3 4
0.4 5
0.5 6
0.6 7
0.7 8
0.8 9
0.9 10
1.0 11
1.1 12
1.2 13
1.3 13
1.4 14
1.5 15
1.6 15
1.7 16
1.8 17
1.9 17
2.0 18
2.1 19
2.2 19
2.3 20
2.4 20
2.5 21
2.6 18
2.7 15
2.8 11
2.9 6
I add 45 degree layers of 100gr cloth on top of all 300g 0 degree layers for buckling resistance and easier layout.
I use 21 layers from 2.4 - 3.0 to make the bottom uniform.
These modifications should add to the strength considerably.
So the laminating schedule is the following (L denotes a combination of 300gr 0degree and 100g 45 degree layers):
2*L 0.0-3.0
1*L 0.2-3.0
1*L 0.3-3.0
1*L 0.4-3.0
1*L 0.5-3.0
1*L 0.6-3.0
1*L 0.6-3.0
1*L 0.7-3.0
1*L 0.8-3.0
1*L 0.9-3.0
1*L 1.0-3.0
1*L 1.1-3.0
1*L 1.2-3.0
1*L 1.4-3.0
1*L 1.5-3.0
1*L 1.7-3.0
1*L 1.8-3.0
1*L 2.0-3.0
1*L 2.1-3.0
1*L 2.3-3.0
1*L 2.4-3.0
Questions:
- Is the choice of tensile strength sensible?
- Are all the design choices (putting sail force at the top, adding layers to the schedule) safe?
- Are there any flaws in the calculations or logic?
Oh, forgot to mention that AWS is 1.25 * design wind speed according to GL scantling rules.
bump. I hope someone can help me with this.
Still hoping for an answer.
  • · Replies 25 ·
  • · Replies 17 ·
