Designing Voltage Source Inverters for 50V Output Peak Voltage
The discussion revolves around the design of voltage source inverters, specifically targeting an output peak voltage of 50V with a DC input of approximately 55V. Participants explore various aspects of inverter design, including component selection, PWM techniques, load characteristics, and simulation results.
  • Homework-related
  • One participant expresses confusion about the design process of inverters and seeks clarity on necessary parameters and calculations for load current and component ratings.
  • Another participant emphasizes that design projects often require individual determination of parameters based on requirements and trade-offs.
  • Clarification is provided regarding the type of inverter being used (H-bridge) and the PWM method (comparing sine and triangular waves) for generating output signals.
  • Concerns are raised about the ratings of switching devices, with suggestions to consider V and I ratings and the Safe Operating Area (SOA) specifications.
  • A participant mentions the importance of understanding whether the inverter will supply only real power or also reactive power.
  • Discussion includes the need to check datasheets for IGBTs and the impact of load characteristics on expected pulsed current.
  • One participant reports simulation results from MATLAB/Simulink, noting voltage spikes and non-sinusoidal output, and asks about methods to achieve a cleaner output waveform.
  • Suggestions are made to consider adding LC filters to improve output waveform quality and to explore the basic circuitry used in the simulation for further assistance.
Participants express varying levels of understanding regarding inverter design, PWM techniques, and simulation results. There is no consensus on specific solutions to the issues raised, particularly concerning the elimination of voltage spikes and achieving a sinusoidal output.
Participants highlight the importance of understanding the characteristics of the load and the implications of switching device ratings. There are unresolved questions about the design process and specific methodologies for achieving desired output characteristics.
This discussion may be useful for individuals interested in inverter design, PWM techniques, and simulation of electrical circuits, particularly in the context of voltage source inverters and their applications.
kiamzattu
Hello every1
I have a basic question bout Design of inverters(Voltage source inverters). Wel Actually what does designing mean?
I have to design a inverter whose output Peak voltage is 50v. The input DC voltage wil b around 55V.I'm using single phase full bridge inverter And i'll b using R load in one case and RL in another case. Now wat r the other parameters tat r needed in designing an inverter. My output frequency is 50 Hz and I'm using sinosoidal PWM to trigger my switching devices(MOSFETS). Now how should i calculate wat is my load current?How do i determine the rating of my switching devices and power rating of my whole inverter? I'm entirely clueless. Is ther any step by step procedure for inverter design? any help is greatly appreciated.
Thanks in advance.
First of all, please proofread your post. If every single sentence has multiple grammatical and structural mistakes, then it appears that you are not being serious. It shows your lack of care for the particular problem at hand.
Secondly, since this is appears to be a design project, most of your parameters will be logically determined by yourself. This allows you to view the design process, which is all about requirements and trade-off's. What are some trade-offs that can be associated with an inverter? What are some requirements for the particular design? I'm sorry to say, but for the most part a design project does not have detailed steps for you to take.
anbullet said:
Hello every1
Thanks in advance.
I agree with both of ravioli's points. anbullet -- check your PM box.
As to the questions, I'm not sure that you understand what a "power inverter" is. It generally is a device that takes in a DC voltage, and generates an AC output voltage, usually at AC Mains voltage levels (50Hz, 220Vrms, for example). The quality of the output "sine wave" waveform depends on how much you are willing to spend on the intermediate circuitry, and also on the character of the load impedance.
I don't know what you mean by "I'm using single phase full bridge inverter". By bridge, do you mean an H-bridge output stage? And what do you mean by sinusoidal PWM?
You could search at wikipedia.org for some background on inverter design, and use google to get the basics. If you have specific questions, point us to the page you are studying, and ask the specific question. And please take care to type carefully, and explain yourself clearly.
Thanks for the reply .
@ravioli
I'm really sorry for my grammar and spellings. English is not my mother tongue.
@ Berekman
Yes full bridge inverter is H-bridge inverter. Sinusoidal PWM means I'm comparing a sine wave and a triangular wave for generating PWM pulses.
I have my input voltage and output voltage values.
I understand the above point. But before actually going into the output waveforms, I need to determine the ratings of my switches.what is the way to do that?
Hope I'm clear. Forgive me if not. Its the best of my grammar. took nearly 15 min to post it.
Thank you for the effort, anbullet, that makes it so much easier to understand your question.
I'm still a little hazy on the PWM part, though. Could you point me to a reference that describes how the PWM is used with the H-bridge to generate an output sinusoidal power waveform? I don't know enough about inverter design to know what is being done in the comparison you mention.
As for your switch ratings, they will need the V and I ratings to be large enough, and you will also need to check their Safe Operating Area (SOA) specifications, as the max I and max V ratings may not necessarily be used at the same time.
I appreciate the effort. I'll try to post something tomorrow that will help you out. I don't necessarily have the greatest expertise with PWM, but I can look it up during the day tomorrow.
I do have one question, though. Will your inverter supply only real power, or will the inverter have to supply reactive power?
@ Berekman
PWM is just for switching the MOSFETS. When i compare a sine and a triangle,square pulses are generated. These pulses are used as switching signals and are given to the gates of MOSFETS.I've attached a pdf file giving a overview of how PWM is used in inverters to obtain output waveforms.
@ ravioli
My inverter needs to supply only real power.
Anbullet, check out a few datasheets for IBGT's over at Mouser. They are fairly informative and will give you a few clues on what is out there, and what capabilities IGBT's have. Since PWM deals primarily with, well, pulses, you can assume that the resistive load will see the 50 volts at once at the during the pulses. From there, once you know the expected characteristics of the load, you can easily calculate what kind of pulsed current you should be expecting to go through the IGBT's.
Another note, I believe that the 55 Vdc source, and a 50 Vac peak output is fairly important. Since two transistors will usually be on, you will need to pay particular attention to the graphs in the datasheets. By symmetry of the circuit, you will only have a budget of about 2.5 Volts for Vce per transistor when the transistor is on.
Lastly, unless told otherwise, don't underestimate heat.
Thank you all for the help.
Will check out informations about IGBT and others.I still have some doubts, will post it after going through the datasheets.
Thanks again
Hi everyone
Before implementing the hardware part of my inverter i simulated my circuit using Simulink(MATLAB). I used a DC input source of value 55v, MOSFETS as my switching devices,PWM method for triggering them and output load of 50ohm. I've attached a screenshot of my output voltage.
Now i have some doubts in it. First of all my output peak value must be only 50volts. But I'm getting voltage spikes which cause my output to be around 54volts. Is there any way of eliminating these voltage spikes so that my peak output value is reduced (Preferbly 50volts)?
Secondly as you can see my output is not sinusoidal. I haven't added any filters in my circuit as of now. Can i add an LC filter ?Will a LC filter help in eliminating the switching frequencies so that my output is sinusoidal ( or atleast square) with a frequency of 50 hertz?
Is there any rule of thumb or steps to design LC filter so that it eliminates all the switching frequencies and allows only 50 hertz?
I know I'm asking too many questions, sorry for that.
hi,
well before i suggest u anything i wld like to knw the basic circuitry in your simulink.
may be i could help u with it because i too use MATLAB and as far as i knw u could be optimistic about ur output.
And yes with ur filter circuit try adding some reactive components in ur load.
Basically L & C, they work well for an approximate sinosuidal output.
Hope this may help u
  • · Replies 22 ·
  • · Replies 38 ·
