Determine if sqrt(-3) is an element in a splitting field
The discussion revolves around determining whether sqrt(-3) is an element of the splitting field L generated by the polynomial x^2+x+1 over the rational numbers, as well as whether it belongs to the field Q(a), where a is a complex root of x^3+x+1. Participants suggest starting the solution by finding the roots of the polynomials involved. The complexity of the problem arises from the nature of the roots and their relationship to the elements in the fields. Ultimately, the discussion emphasizes the importance of understanding polynomial roots in relation to field extensions.
gop
L is the splitting field generated by x^2+x+1 (over \mathbb{Q})
a) Is \sqrt{-3} an element of L?
b) Is sqrt(-3) an element of \mathbb{Q}(a), where a is a complex root of x^3+x+1?
Really no idea.
You should start by finding the roots of the given polynomials.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
