Determine inner wall temp of a pipe....
This discussion focuses on determining the inner wall temperature of a pipe under subsea conditions, specifically for laminar flow scenarios involving water and methane. Key parameters include a fluid temperature of 66 degrees, ambient temperature of 4 degrees, wall thickness of 12.7mm, and an inner radius of 0.1905. Participants recommend using the average fluid temperature for initial calculations and suggest employing the Nusselt number correlations, while noting that the Dittus-Boelter equation is applicable only for turbulent flow. For comprehensive guidance, "Transport Phenomena" by Bird, Stewart, and Lightfoot is recommended.
  • Understanding of heat transfer principles
  • Familiarity with Nusselt number correlations
  • Knowledge of fluid dynamics, particularly laminar flow
  • Basic equations for thermal conductivity and viscosity
  • Research the application of Nusselt number correlations for laminar flow
  • Study the Dittus-Boelter equation and its limitations
  • Explore methods for estimating wall temperature using average fluid temperature
  • Read "Transport Phenomena" by Bird, Stewart, and Lightfoot for detailed methodologies
Engineers and researchers involved in thermal analysis, particularly those working with fluid dynamics in subsea environments, will benefit from this discussion.
shevir1
I have derived a few equations to determine temp distribution through pipe wall in subsea conditions.
However I am finding it difficult to determine what the wall temperature will be. I need to know and use this temperature to further my analysis.
As of now I know the following parameters:
-Fluid temperature within pipe = 66 degrees
-Ambient temperature = 4 degrees
-Wall thickness = 12.7mm
-Inner radius = 0.1905
Could you recommend a way I can determine the inner wall temperature? or point me in the right direction.
Without this wall temp I am also unable to calculate heat flow rate or convection coefficients for inner and outer fluid.
Many thanks
You need to know the heat transfer coefficients inside and outside the pipe. Do you know how to estimate these?
I have looked up many correlations, an example being nusselts number. but even in that correlation it required me to know the viscosity at wall, yet i still don't have the wall temperature, needed to calculate that.
any other estimations i could try?
The Nusselt number correlations are the way to go. Since you don't have the temperature at the wall, you will need to use trial and error. But, the term involving the viscosity at the wall is only a minor correction. You can start out using the average temperature of the fluid.
chet
ok, yes i was thinking of using an average temp. shall do. thanks
Average temperature of what?
You have an average temperature of the wall from entrance to exit.
an average temperatue of the fluid from entrance to exit.
an average temperature of the ambient fluid of convecton at entrance to exit.
Which one will you choose?
i was going for the second. average temp of fluid flowing in the pipe
Could you somehow use the Seebeck effect to measure its temperature? I honestly have no idea how it would work, but I figured if you touch a different piece of metal to it and measure the voltage, you could do some math to convert it into a temperature.
Since the viscosity of the fluid at the wall temperature is unknown, I am just wondering whether you can adopt the Dittus-Boelter equation/model to simplify the engineering estimations. The Dittus-Boelter equation is an explicit method for calculating the Nusselt number. It is easy to solve, and is an acceptable estimate for cases when there is a small temperature difference between bulk fluid and the pipe wall.
Hi pocketengineer, thanks for the suggestion. However the Dittus Boelter model applies for turbuent flow, where as mine is laminar.
I am doing for two cases water in pipe and methane in pipe, so i will be able to easily apply Dittus etc equation to the later.
For the case with water in pipe (laminar flow) I will proceed with chestmillers suggestion in using the average fluid temp.
Thanks
Thanks
If you want all the details on how to do it, see Transport Phenomena by Bird, Stewart, and Lightfoot.
