Determine the convergence or divergence of the sequence
The sequence defined by an = (1*3*5*...*(2n-1))/(2n)^n converges to 0 as n approaches infinity. The reasoning involves comparing the product of odd numbers in the numerator to the power of 2 in the denominator, specifically showing that the terms are less than 1/(2n). As n increases, the limit of the sequence approaches zero, confirming its convergence. The discussion highlights the importance of understanding the relationship between the terms in the sequence and their limits. Ultimately, the sequence converges, with the limit being zero.
zak1989
Determine the convergence or divergence of the sequence with the given nth term. If the sequence converges find its limit.
an = (1*3*5*...*(2n-1))/(2n)n
lim n->infinity an = L
The answer in the book shows:
1/2n * 3/2n * 5/2n...(2n-1)/2n less than 1/2n
So, lim n->infinity an = 0, converges
I don't understand where the 1/2n * 3/2n * 5/2n...(2n-1)/2n less than 1/2n comes from. I'm obviously missing something. Could anyone please explain that part to me? I'd really appreciate any help at all. Thanks :)
Obviously ##1 \cdot 2 \cdot 3 \dots (2n-1) \cdot (2n) < (2n)^{n}##, because in the first product all factors except the last one are smaller than in the second product.
Therefore, also ##\frac{1 \cdot 3 \cdot 5 \dots (2n-1)}{(2n)^{n}}<\frac{1 \cdot 3 \cdot 5 \dots (2n-1)}{1 \cdot 2 \cdot 3 \dots (2n-1) \cdot (2n)}=\frac{1}{2 \cdot 4 \dots (2n)}##.
Can you now tell that the sequence is convergent?
For n sufficiently large, 0 < 1/2n < 3/2n < 5/2n < ... < (2n-1)/2n < 1. So you're multiplying 1/(2n) by something which is strictly less than 1, which means that the result is strictly less than 1/(2n).
Thanks for your help, but I'm still not getting it. When I see the sequence an = (1*3*5*...*(2n-1))/(2n)^n I would think it looks something like 1/2(1)^1 * 3/2(2)^2 * 5/2(3)^3 ... Is that wrong? I don't understand where the exponent n is going from the denominator.
Yes; it's
<br /> \frac1{2n} \times \frac3{2n} \times \cdots \times \frac{2n-1}{2n} = \frac{1 \times 3 \times \cdots \times (2n-1)}{(2n)^n}<br />
since there are n factors and the denominator is the same for each.
Both, if you mean ##\frac 1 {2n}##, ##\frac 3 {2n}##, and so on, you need parentheses around each denominator. Otherwise what both of you wrote would be interpreted as (1/2) * n, (3/2) * n, etc.
Ok now I understand why those two equations are equal, thanks. It seems so obvious now. What I still don't understand is how does saying 1/2n * 3/2n * 5/2n...(2n-1)/2n less than 1/2n help me conclude that the sequence diverges?
^ Actually, the sequence converges, because you can make the quotient arbitrarily close to zero by choosing sufficiently large n.
If \epsilon &gt; 0, does there exist a positive integer N such that 1/(2N) &lt; \epsilon?
What does that tell you about the convergence or divergence of the sequence?
Oh ok so the limit as n goes to infinity is zero which means it converges, but I'm a little lost. How do I know the limit is zero? Thanks for all your help I really appreciate it :)
  • · Replies 16 ·
