Determine the magnitude and direction of the force on each charge
The problem involves two positive and two negative charges placed at the corners of a square, with the task of determining the magnitude and direction of the forces acting on each charge. The context is rooted in electrostatics, specifically applying Coulomb's Law to a configuration of charges.
  • Participants discuss the application of Coulomb's Law and the concept of electric fields. There are inquiries about the relevance of previous problems involving charges on a horizontal plane and how to approach the calculation of forces in this square configuration. Some participants suggest breaking down forces into components and using symmetry to simplify calculations.
Participants are actively engaging with the problem, sharing their understanding and confusion regarding the setup and calculations. Some guidance has been offered regarding the vector nature of forces and the importance of considering both attractive and repulsive interactions. However, there is no explicit consensus on the approach to take, and multiple interpretations are being explored.
There are indications of confusion regarding the application of vector addition and the specific calculations needed for forces between the charges. The discussion also highlights the potential for misunderstanding the roles of different charges and their respective distances in the calculations.
swede5670
Two Q = +5.86 mC charges are placed at opposite corners of a square d = 0.9 m on each side, and -Q = -5.86 mC charges are placed at the remaining corners.
Determine the magnitude and direction of the force on each charge.
Coulomb's Law
My teacher just gave this to us without any explanation of how to go about solving such a problem. I have a basic understanding of electric fields and I know coulomb's law, can someone please help me work through this? I'm wondering if this is at all similar to the problems where the charges are simply placed on a horizontal plane with a set distance between two charges. I know how to solve those problems, but I'm not sure if you use the same strategy to solve this problem.
Thanks in advance
Coulomb's Law
Thanks in advance
In this problem you are using the F = q*E
You need to take the ∑ of the Forces. But as before in your other problem you are dealing with vectors, and that is important since you have charges separated in both x and y.
Happily though because of symmetry and the uniform charges and distances, once you determine the Force on one from the other 3, you should see that the other answers are easily inferred.
So for each charge F = q* E
And E is the sum of the forces?
And where are the X and Y planes drawn for this situation?
The charges themselves occupy the x-y plane. They are in a square of .9m.
At any charge there is an equal charge of opposite sign at .9m in x direction and the same in y direction. Then there is the 3rd charge (same sign) along the diagonal that will contribute an x and a y component.
I'm still a bit confused by what your telling me, I talked to a friend and here is what he said:
To calculate the forces you really only need to do it once and then apply the direction as if you were doing it in each quadrant.
. K= 9x109. r = .9m for doing the adj and r = √.92+.92 for the ones across the square. This gives you the chance to break them into x and y components and add them to get the ΣF.
Does that seem right to you? I couldn't really decipher what he was saying so if you can could you help me understand it?
Since all the charges are the same (except for sign) it might be easier to calculate it symbolically.
For the 1q you have an attractive Force in vector notation that looks like - q2/d2 i - q2/d2 j and the one on the diagonal has a repulsive force with components of +q2/2d2*cosθ i + q2/2d2*sinθ j
In this case sinθ and cosθ are equal to √2/2 which should help a little to calculate the magnitudes.
You say
"for the 1q"
What is the 1q? Is it the one quadrant? You gave me two equations for the vectors for attractive and repulsive forces, do I need to add these two vectors? I don't know what I need to do. I can plug the numbers in for these equations:
q2/d2 i - q2/d2 j
But once I plug the numbers into both what do I do?
Sorry, but I'm becoming fairly confused.
In your problem opposite charges are repelling and adjacent charges are attracting. Let F be the forces between adjacent charges, Since charges are same except sign, forces between opposite charges will be F/(2). At any corner resultant of Fs is in the opposite direction to F/2. Resultant of two adjacent forces = (2)^1/2*F
Therefore Fr = (2)^1/2*F - F/2
Here F = k* (5.86*10*-3)^2/(0.9)^2
swede5670 said:
You say
"for the 1q"
q2/d2 i - q2/d2 j
I meant to say "for 1 charge q". For that charge you will have 3 forces to be added by superposition. You must treat these forces as vectors.
From 1 corner it will be -q2/d2 and it will be along the x-axis say. Give that force a value
F = -q2/d2 i
From the other adjacent corner you have the same magnitude force but it is directed along the y axis.
F = -q2/d2 j
From the opposite corner the magnitude of the force |Force| will be + q2/2d2 because it is a distance of d*√2 away. But it will have both an x and a y component relative to the other charges.
F = q2/2d2cosθ i + q2/2d2sinθ j
Substitute √2/2 for the sinθ and cosθ and add the 3 F's all together.
This vector sum is your answer. Pay careful attention to the sign, and note that I left out a factor of k for simplification. Since the i and j components are equal then you know your angle direction is along the diagonal. The sign of your answer should help you to understand whether it is attractive or repulsive.
  • · Replies 22 ·
10K
  • · Replies 30 ·
10K
