Determine the singularities and evaluate residues
  • Thread starter Thread starter brydustin
    Singularities
brydustin
f(z) = \frac{z*exp(+i*z)}{z^2+a^2}
Res(f,z_0) = lim_z->z_0 (1/(m-1)!) d^{m-1}/dz^{m-1} {(z-z_o)^m f(z)}
I have no clue how to do this because I don't know how to determine the order of the pole for a function of this form. For example, I could easily do this for a function like (1/(z^2+a^2))
Hi there friend, consider expanding the numerator and the denominator separately in a Laurent series and then multiply them together to pick out the coefficient of the z^-1 term
Okay... . I'm now specifically asking how to compute it for the essential singularity, when z=∞ what is the residue?
I thought you needed to determine the singularities and their residues? I don't know if you've learned this yet, but if you have a function f(z)=g(z)/h(z) where h(z0)=0 and g(z0)!= 0 then the order of the pole at z0 is equal to the order of the zero at h(z0). The order of the zero can be found by looking at the order of the first non-vanishing coefficient in the series expansion of h(z) around z0. In this case, we have h(z)=z^2+a^2 so for example h(ia) = 0. If we try to expand in a series h(z)=c0 +c1(z-ia)+c2(z-ia)^2+... then c0=0 because h(ia) = 0 and c1=dh(z)/dz evaluated at z=ia which gives c1=2ia. That's non-vanishing so the order of the zero at h(ia) is 1. Hence there's a simple pole.
Then the residue at z=ia is given by g(ia)/h'(ia).
I could be wrong because it's been a while, but good luck.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
