Determining a zero force member visually
  • Thread starter Thread starter member 392791
    Force Member Zero
4 replies · 4K views
member 392791
Hello,
When given a truss structure, how does one tell visually just by looking at the structure which members are zero force members?
From Wiki:
  • "If only two members meet in an unloaded joint, both are zero-force members.
  • If three members meet in an unloaded joint of which two are in a direct line with one another, then the third member is a zero-force member.
  • If two members meet in a loaded joint and the line of action of the load coincides with one of the members, the other member is a zero-force member."
An unloaded joint is a joint where no external forces are applied , or a joint where there is no external reaction force.
A loaded joint is a joint where external forces are applied , or a joint where there is an external reaction force.
So that means if you have 4 members at a joint, then none of the members can be zero force members? I am looking at a homework problem and this is the case where 4 members meet and yet one or more of the members is a zero force member. I thought it was only 3 members meeting
No, it just means you can't decide if they are zero force members by looking at that joint. But the other end of each member is connected to a different joint, and that joint might tell you it is a zero force member.
Of course it is also possible for a member in a complicated structure to have zero force just by happenstance, but that's not very interesting.
