Determining angular frequency and amplitude for SHM
The discussion focuses on determining the angular frequency and amplitude of simple harmonic motion (SHM) for a mass-spring system. The angular frequency, ω0, is derived from the initial speed and amplitude, leading to the formula ω0 = v0/A. For a modified system with different speeds and positions, the conservation of energy approach is suggested to relate kinetic and potential energy, resulting in a formula for ω0 based on the given quantities. The amplitude A can also be expressed in terms of ω0, velocity, and position, leading to A = sqrt[(v/ω0)² + x²]. The participants confirm the validity of their calculations and explore alternative methods for simplification.
Elvis 123456789
A mass "m" is attached to a spring of constant "k" and is observed to have an amplitude "A" speed of "v0" as it passes through the origin.
a) What is the angular frequency of the motion in terms of "A" and "v0"?
b) Suppose the system is adjusted so that the mass has speed "v1" at position "x1" and speed "v2" at position "x2". Find the angular frequency, "ω0", and amplitude "A" in terms of these given quantities. Simplify your results.
x = A*sin(ω0*t -φ)
v = A*ω0*cos(ω0*t -φ)
so for the first part
x(t0) = A*sin(ω0*t0 -φ) = 0
therefore φ = ω0*t0
v(t0) = A*ω0*cos(ω0*t0 -φ) = v0
therefore ω0 = v0/A
for part b.)
x1 = A*sin(ω0*Δt1)
v1 = A*ω0*cos(ω0*Δt1)
x2 = A*sin(ω0*Δt2)
v2 = A*ω0*cos(ω0*Δt2)
where Δt1 = t1 - t0
and Δt2 = t2 - t0theres four unknowns and four equations so I know I should be able to solve for ω0 and A, but I can't seem to untangle all these trig functions. any hints?
I suggest taking a look at an energy conservation approach. Both the KE and PE expressions square their variable so position and velocity directions don't matter there.
Ok so using conservation of energy
KE1 + PE1 = KE2 + PE2
1/2*m*v12 + 1/2*k*x12 = 1/2*m*v22 + 1/2*k*x22
canceling the halves and dividing by "m" on both sides
v12 + ω02*x12 = v22 + ω02*x22
then rearranging for ω0
ω0 = sqrt [ (v12 - v22)/(x22 - x12)
for the amplitude I use the fact that the total energy at any time is equal to 1/2*k*A2
so KE1 + PE1 = 1/2*k*A2
plugging in and rearranging I get
A = sqrt [ x12 + v12 * (x22 - x12)/(v12 - v22) ]
does this look okay?
That looks good.
For the amplitude you could also have chosen just one of the given (x,v) pairs to find the total energy. The resulting expression might be a bit cleaner...
gneill said:
That looks good.
I don't quite understand what you mean. I chose just x1 and v1 but x2 and v2 factor in because I had to divide by the mass again to get the angular frequency since they didn't want the answer in terms of "k"
You're right, I missed that stipulation. Mind you, if you find ##\omega_o## first, you should be able to use that in the amplitude expression. You should be able to reach:
##A = \sqrt{\left(\frac{v}{\omega_o}\right)^2 + x^2}##
Yes, that's the expression that I arrived at before I plugged in the corresponding values. Thanks for the help :)
